Soooo, I've been having issues getting my car started after a tranny swap and timing belt job. Well I finally got the car started and everything was done and It was time to align the shifter. Well it was terrible at first, but now I got it to go into 3-6 ok and it engages the gears... 1st and 2nd go into the gear slot just fine, but it doesnt engage the gear. Reverse is the same way. I've tried adjusting it several times but nothing. I feel like the tranny I bought my be bad or that something is up with my shift linkage. I can't see how it could be messed up though since i Just swapped everything over from one tranny to the other. I reused my old slave cylinder so I know its ok, and I know my clutch is fine because I inspected it during the swap.
I guess it may be possible that a bushing got lost in the shift likage swap, is that something that could happen and would cause these issues? I just dont see why it will go into 1st and 2nd just fine but not engage. It seems like if it were a linkage problem it wouldnt even go into those gears. Any help would be greatly appreciated.
and yes, I have searched for hours for someone with a similar problem. No def answers yet
