Results 1 to 23 of 23
    Senior Member Three Rings FlyingGuy's Avatar
    May 23 2008
    YES! im STAGE 2+ now!!!
    i was runnin my GIAC for quite a while by itself... but this past weekend i got my full exhaust put on! this will definately keep me company til i got stg3. it seems like it spools up YESTERDAY and has a sweet tone to it. purchase of the exhaust made possible on AZ
    are there ballpark numbers or times i can expect with this setup? just wonderin, cause our track is closed for the year, and no AWD dyno in town
    2001.5 S4 6spd
    GIAC
    Labree split downpipes
    Borla cat-back (with test pipes at the moment)
    RS4 clutch
    so... whats next? aside from the obvious stg 3 save-up. VAST water/meth?
    pics up. sound clip soon!!!
    Jun 14 2007
    2000 S4
    Connecticut
    Re: YES! im STAGE 2+ now!!!
    Awesome man, sounds great... Stage 1 to 2+ is for sure a big difference. The added flow from the downpipes is a huge benefit... W/M will make a great difference as well, what's your IC setup?
    Aug 06 2008
    Canadia
    next? i recommend BF SMIC's.
    I remember reading that stock inter coolers have a 2psi drop between the inlet and outlet at full throttle, not sure how much truth there is to that, but I do believe they are not the most free flowing.
    the B5 S4 is like the mafia... there is only one way out!
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Get a true dual exhaust. Soo much better than a single set up.
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Welcome to the club! I recently joined too...
    Did you do DP/Exhaust install yourself?
    Suspension upgrade?
    SMICs?
    My next project will either be K04 (minus SMIC) setup or suspension upgrade. I feel like my shocks are about to die.
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    I prefer a single setup myself...I think it sounds so much better than a dual setup imo.
    May 23 2008
    didnt do the install myself. i have neither the tools, time, or know how to have done it myself. took it to WMS. (glad i did too, got to see a B5 rs4 there gettin some work done!)
    anyway, im running stock IC. i heard/read that ER ICs are pretty top tier, but hard to come by. i have the samco TBB and some 710ns, boost gauge, and the coolant temp sensor. clutch went out last year, so i figure RS4 was a smart choice. NO suspension or brake work or intake. gotta do front control arms here kinda soon though, like, now-ish.
    gunna try some toluene next time im "out and about".
    Dec 14 2007
    Motorcycles
    Bainbridge, NY
    Quote Originally Posted by revhards4 View Post
    I agree. NA's can have true duals and have an awesome sound. Turbo motors with duals sound... strange.
    B6 Avant 1.8TQM - 2871RS beater. I am not a smart man.
    May 13 2008
    Medway, MA
    Sweet, must pull pretty hard. Get a pic of the car and a vid of the exhaust, i'd like to see it. Do you wanna run it at the track?
    Daily: 1998.5 A4 1.8TQM
    Fun Car: 1990 Mazda Miata
    May 23 2008
    Quote Originally Posted by cmurphy2266 View Post
    will do. ill try to get pic and vid up this weekend. im not lookin to take it to willow springs or nothin... id just like to test my 1/4
    May 23 2008
    pics added. soud clip soon!
    Registered Member Two Rings
    Aug 18 2008
    Wrong Island
    congrads like the s4
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Bang for buck. go with JHM FMIC. Youre a cali guy and suffer from the same heatsoak I did.
    It'll fit behind your stock bumper with plenty of chopping of course. But you can go much stealthier than my Rieger bumper.
    Even if youre not stage 3 this is a GOOD idea.
    --Black 2001.5 -S4- 10secS4 Tuned
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    I have Giac X plus piggies and borla cat back single 3inch. I ran a 13.5 @ 103 in the spring, but the clutch can't hold off the line at higher RPMs. You should be somewhere in the low to mid 13s with a good clutch, my 60 was horrible...
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    May 23 2008
    Quote Originally Posted by Grangalan View Post
    ..what front mount? i dont see one
    and NATE, what octane was that on? race file?
    cali heat + 91 oct =
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Quote Originally Posted by FlyingGuy View Post
    100oct race file makes bigggg difference
    May 23 2008
    ya im still waiting to try my race gas file. anyone thats run a toluene mix in premium, do u stay on the standard file? or mix a high solution and switch to the race file? was thinkin about gettin some toluene and seeing how the car reacts to it, 20% mixture.
    gotta friends friend that wants to race. stock g37-s coupe. thoughts?
    Veteran Member Four Rings VonPooper's Avatar
    Feb 10 2007
    4RUNNER
    you will walk.
    EARTH PEOPLE.
    Senior Member Three Rings Reaxion's Avatar
    May 19 2008
    2001.5 S4 AVANT
    Berkeley / O.C. , Ca
    de_stroyed.
    Current:
    2001.5 S4 Avant
    2000 BMW 323ci
    2005 A8 L (10/29/07) R.I.P.
    May 23 2008
    Quote Originally Posted by Reaxion View Post
    de_stroyed.
    referring to the g37, i hope?
    theres an srt-4 neon thats been ricing around, seems quicker than stock. i know they can be kinda quick, so i might try him next. from a launch first though
    Veteran Member Three Rings BoostinonYOU's Avatar
    Apr 03 2006
    02 s4, 08 Thundra, 08 gsxr 1000
    Moorpark, Ca
    Quote Originally Posted by nateS4 View Post
    Should be in the high 12's
    APR Stage 1 13.0009 @ 105 FULL INTERIOR | 100 OCT RACE GAS
    APR Stage 2+ 12.87. @ 109.10 1.89 60FT. FULL INTERIOR FULL EXHAUST | 93/110 mix
    http://www.youtube.com/watch?v=pCPXI5hMOUI
    I have a faster 1/4 time but no slip, didn't bring my helmet and promptly got kicked off the track w/o time slip :(
    APR | JHM | OZ RACING |
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    if the srt4 has a big turbo,just race him from a dig and stop at 20mph so he doesnt spool haha (kidding of course)
    get some coilovers,intercooler of your choice (ERs are $$$$),and obviously do a CC mod if you havent already (here comes fighting)...then maybe JHM solid shifter,DTS from AWE or ASP,snub/motor/trans mounts,etc
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Quote Originally Posted by jutny View Post
    I would like to think that comment would be highly disputed; considering asp is prob one of the best sounded ots exhaust available
    2010 Brilliant Black/Magma Red S4
