Results 1 to 7 of 7
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Heating issue...
    Ok...so i had no heat in my car and my water temp was dropping down when i would get on the highway.Logical thing to do was replace the tsat. Thermostat was done and it fixed my issue somewhat. My water temps stays dead center now but the heat only works when i'm driving. has anyone ever had an issue like this??
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    May 31 2008
    New York
    Re: Heating issue...
    anyone????
    Aug 06 2008
    Canadia
    sounds like low coolant or an air bubble.
    the B5 S4 is like the mafia... there is only one way out!
    May 31 2008
    New York
    Quote Originally Posted by MacDaddy View Post
    coolant levels are fine...it was changed when the tstat was done.
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Quote Originally Posted by s42k5b View Post
    PM fit4ataking (Andy).
    He's a certified Audi tech out here in the DC/MD/VA area. I went to him this past week to see if he could tighten my flanges up better than I could, thats when he found out one of my flange studs were bent.
    EDIT: He works for either Tischer Audi or Criswell Audi (one of the two dealerships in MD)
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Could be a bad temp sensor
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    May 31 2008
    New York
    Quote Originally Posted by RolledMySTi View Post
    I already have and updated one..with a bad CTS I would be having erratic water temp readings wouldnt I?
