Results 1 to 10 of 10
    Registered Member Two Rings
    Feb 07 2008
    04 A4 1.8t 6spd
    stratford ct
    problem with trunk
    hi. i noticed yesterday that my trunk doesnt open ! i mean it opens when i use remote, but it doesnt when i use a switch or 'handle' .. any ideas what to do ?
    Registered Member Three Rings nytildie914's Avatar
    Sep 26 2008
    B/B 2003 Audi A4 3.0 Quattro
    Westchester.NY and Naples.FL
    Re: problem with trunk
    Quote Originally Posted by voytekA4 View Post
    i have the same problem, i can only use my remote to open the trunk, not the little trunk handle in my car...
    Aug 08 2008
    A4 B6 1.9 TDI
    Belgium
    Try to unlock the car with you're key and i mean not with the remote but put it in the (trunk) lock and turn, and then try to open it with the handle.
    I know some guys that had the same problem.
    Let me know if it worked.
    Feb 07 2008
    04 A4 1.8t 6spd
    stratford ct
    tried open it with the key .. it works . but 'handle' and 'switch' still not working ..
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by nytildie914 View Post
    Same here only opens with remote or from driver's side door. Also tried using the manual method to unlock the trunk also no go. Been like that for a year now... too busy modding to spend $$$ on this. I think I read of someone on AW replacing some switch/part in the trunklid. Not sure of part# or price. Maybe someone else can chime in on this.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Feb 07 2008
    04 A4 1.8t 6spd
    stratford ct
    i my case that button on side of driver siede door doesnt work either... i can only use remote or key to open trunk manually . . stupid german cars . . there is always something wrong with them . .
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by Soiree View Post
    I remember someone fixing the same problem like this aswell.
    Maybe you have to turn the key one way and pull it out without turning it back?
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Tonight my trunk latch no longer engages. No matter if I try slamming the trunk, or holding it shut tightly while I lock the car, or softly closing it, it just simply refuses to engage. I was getting it to catch for a little while by holding it and locking, but when I started the car, it shows that the trunk is open. Also when I lock the car, the alarm never beeps, probably due to it thinking that the trunk is still open. I've read some say that the vacuum may have gotten snagged or cut or something, but the part by the hinge still appears fine, and others have said that they had issues with the actual mechanical piece. I'm not quite sure where the vacuum line goes after the trunk hinge, but the rest of my doors still lock fine. Didn't know if anyone had any ideas or help on the matter. Thanks
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Quote Originally Posted by mbgt72 View Post
    Ended up disconnecting the battery and took off all the back paneling to look at the lock mechanism. After ensuring everything was tight and secure I hooked the battery back up and was able to get all the functions to work fine. Not quite sure what was going on, but just glad it's working and hope it keeps working!
    Current: 996TT
    Aug 26 2005
    Yeah, the B6 does not use any vacuum operated locks, everything is electrically operated.
