Results 1 to 10 of 10
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    Recommendations on tire size for 17s please?
    Hello, im going to use my stock 17s for winter and now i'm looking to purchase a set. the problem is that i don't know what tire will fit because my ride is lowered on stasis ss coil overs. im looking for blizzaks to be specific. i used a wheel calculator but i dont think that it would help since i'm not using the stock suspension. i also did a search on the forum and looked for a good half an hour with no results. can somebody recommend me the size or another brand tire that they had a great experience with please? heres a pic to show my current wheel gap if that helps any. thank you very much!
    ~~ engineered in germany... modified in brooklyn ~~
    Veteran Member Three Rings casuso's Avatar
    Sep 19 2006
    Mexico
    Re: Recommendations on tire size for 17s please?
    For 17" you can go 235-45-17(stock tires have this measure) or 245-40-17
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    You may need a different sized tire for the spare if you change sizes.
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    235/45R17. Its what the stock tire size is and should be fine, unless you stepped down to 225/50R17 (I think), which should work as well. But since you say you're in NYC (I'm in NNJ), we haven't gotten much snow lately, so stock tire size should be fine
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    I would step down to 225-45-17. You could also try 215 or 205's but I think 225 should work.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Oct 24 2008
    nyc
    how bout 245/45/17 lowered, rubbing issues on the fender or suspension?
    Jan 06 2008
    Dacia Sandero
    Arizona
    You went the wrong direction. You have to go down (225), not up (245) b/c of your drop. Go with 225/45/17.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Oct 24 2008
    nyc
    oh damn, i just paid for them.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Quote Originally Posted by blackbox619 View Post
    Cancel it bro. Not only are those going to fit dangerously on the stock 7.5" wide wheel, but having a wider tire in the snow is not better.
    EDIT: Just saw it was an auction. GL.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Oct 24 2008
    nyc
    yeah, im gonna see if the buyer lets me. i totally misread the details because the tires were half off. what tire size do u recommend, 215/45?
