Results 1 to 15 of 15
Thread: 750 Rpm's Help
    Established Member Two Rings cab7a4's Avatar
    Oct 09 2008
    Southern California
    Exclamation 750 Rpm's Help
    Once my car warms up it idles at 750 rpms ...seems low cause when i turn the wheel it make that power loss sound!! can anyone else verify what their car normally idles at?
    i have a 2005.5 b7 a4 2.0t
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: 750 Rpm's Help
    have you scanned for any codes? i have on 05.5 and this happens to me along with fuel cuts and it is currently at the dealership. From the research I did I narrowed it down to a bad fuel pressure sensor (throtle sensor) which there was a recall for on June 1 of this year. My VIN didnt fall under this recall. I also found out that it could be excessive wear on the cam lobe (there is a TSB for this) or a bad fuel pump.
    Again this is what I found out for my problem (low idle + fuel cuts) but this might help put you in the right direction. Best of luck
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Oct 09 2008
    Southern California
    Thumbs up Re: 750 Rpm's Help
    Quote Originally Posted by Latin Audi View Post
    thanks alot my friend i will have to investigate....cause the audi dealership near me was no help!!!!!
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: 750 Rpm's Help
    The dealership just called and said I need a new "Fuel sending unit". Never heard of this but from what Ive briefly looked up it just tells your fuel gauge how much fuel you have left. Could this really be causing hard starts?
    Oct 09 2008
    Southern California
    Re: 750 Rpm's Help
    wow...it sounds like it could be more than that...u might want to harass them a little more
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: 750 Rpm's Help
    My car was doing that before the fuel pump went. That car would even stall once in a while.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Re: 750 Rpm's Help
    My car (although its a 1.8T) idles about that too. I'm trying to diagnose why, so I haven't done this, but you can change the idle value with VAG-COM. But I do think that a falling idle is a sign of fuel pump failure, espicially if you're getting a fuel cut too....
    Oct 09 2008
    Southern California
    Re: 750 Rpm's Help
    hey gentleman, i really apprieciate your input and all the positive feedback!!!! thanks so much
    corey
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: 750 Rpm's Help
    yea, im going to talk to them in the morning. I dont believe this part could possibly be causing my problems. Im going to see if they even checked for cam wear or fuel pump. Thanks for the input and ill post back tomorrow when I know more
    Veteran Member Three Rings Alkemix's Avatar
    Apr 23 2008
    2019 Lexus NX (wifes)
    Re: 750 Rpm's Help
    RPM's drop when you turn the wheel in idle. You will notice, if you have a boost gauge that your boost will go up and down too slightly. It's not uncommon in ALL cars. You get that power loss sound, I know what you're talking about. I don't think it's a big deal. Just keep your car at a slow roll when turning your wheel instead of dead stop, unless you are parallel parking. Problem solved? Your car idling at 750 does seem low, but mine idles just under 1k too. I've noticed most 4 cylinder cars do that.
    Gone:
    2008 2.0T Quattro 6 MT Dolphin Grey / APR 91 / APR Catback / APR Intake / Sway Bars
    2013 S4 S-Tronic Black / Magnaflow / USS / STOCK
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    Re: 750 Rpm's Help
    Quote Originally Posted by Alkemix View Post
    The reason you RPM drop when you turn the wheel at Idle is due to the power steering pump adding load to the engine hence the revs drop.
    Oct 09 2008
    Southern California
    Re: 750 Rpm's Help
    Quote Originally Posted by Nico View Post
    i got that point...but it shouldn't drop to the point of your car almost stalling!!! that's the concern i had.
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: 750 Rpm's Help
    Alright, so after all my hard start problems and all the research I did to figure out what the problem was it turns out I was right. I took my car into the dealership last Thrusday I explained to them of my nagging hard starts which would only happen after I've been driving around and I go run some errands and after turning the car on/off 2-3 times it would die w/o even putting it into gear. I told them about the recall on the thrust sensor and of the TSB of excessive cam lobe wear and also asked if they could check the fuel pump.
    I get a call on Friday saying they found the problem and that it was a bad "Fuel Sending Unit". I'd never heard of this so I did my hw and found out its only purpose was to read how much fuel I have left. So obviously I wasnt buying their diagnosis and I called some euro shops and other dealers and they told me it could not possibly be causing my hard starts. I then call the dealer and explain to them that I dont think this Fuel Sending Unit could cause my hard starts and they give me the "...well I have to trust my techs diagnosis" bs. Funny enough they phone me Sat afternoon to say my car is ready and that the dumb teen at the service desk had made a mistake and that it was ACTUALLY a bad low pressure thrust sensor and bad fuel pump control module. Now this sounds more like the cause but how the hell did they tell me the wrong part?? Anyways my car runs fine now so I could not be happier.
    Ive posted below the diagnosis sheet along with an exlpoded assembly of the parts they replaced oh and I DO NOT have a Cabriolet, they fd up.
    Diagnosis:
    Thrust Sensor:
    Fuel Pump:
    Oct 09 2008
    Southern California
    Diagnosis:
    Thrust Sensor:
    Fuel Pump:
    Dude, you are awesome. thanks so much!! i will have to remember that .....forget that im gonna print this :) so that if this starts happening i will know what to do.....thanks so much again
    Apr 23 2008
    Re: 750 Rpm's Help
    Quote Originally Posted by cab7a4 View Post
    Stalling is in a whole new ballpark than a drop in RPM. Get it checked out. still does the problem persist if you're on a slow roll while turning? When you stall, are you intentionally stress testing your car at a dead stop, moving the wheel left and right to see if you can stall it? Or is it that you're doing a normal parking/dead stop maneuver? Actually, when you mentioned power loss sound i imagined you were talking about the stutter of the power steering or the wheel or tires, whatever it is, that you get in a car if you turn your wheel say fully to one direction during a dead stop. Anyways, sounds like you might have something else on your hands.
    Gone:
