Results 1 to 32 of 32
Thread: 2000 s4 problem
    Established Member Two Rings kmoney's Avatar
    May 11 2008
    2000 audi s4
    2000 s4 problem
    i just bought a 2000 s4 two days ago with 130k that drove great at least for the first day i drove it, yesterday i was just driving home from school and i noticed that every once in a while i hear a strong grind coming from the motor, also i smell a strong burning smell and when i pop the hood and look in the back i can see small waves of blue smoke and smell the burn strongly. any ideas?
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    Re: 2000 s4 problem
    Blue smoke woo hoo your turbos are gone buddy. Sorry did you buy from a dealer or private seller? Go return it.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: 2000 s4 problem
    You might want to look into getting a refund.
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Re: 2000 s4 problem
    Instructions for you to follow:
    1. Get wooden bat
    2. Take car back to where you bought it
    3. Demand a refund
    2010 Brilliant Black/Magma Red S4
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    they seem to spool up great still but i guess they are going, i did buy it from a dealer, luckily its still under warranty so maybe ill get two new turbos out of it
    Mar 11 2008
    san diego ca
    Re: 2000 s4 problem
    Quote Originally Posted by kmoney View Post
    You better hope you get new turbos because those turbos are fried. Blue smoke is never good my friend.
    Senior Member Two Rings sti4now's Avatar
    Oct 21 2008
    Turbo M3
    NC
    Re: 2000 s4 problem
    Go stage 3 and dont look back...
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    i hope they really check into it though the salesman assured me that the mechanics check over everything and that there was nothing wrong with it, the check engine light is on too i hope it has to do with what i mentioned and not something else
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Re: 2000 s4 problem
    Stupid dealer selling a S4 with a warranty that has bad turbos.........he should have just whole saled it at the auction or something......go take him for some Ko4's
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    its an extremely light blue smoke if that matters
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    you guys think if i did need new turbos i could ask them to put k04s in?
    Senior Member Three Rings LIFES4's Avatar
    Aug 01 2007
    2000 S4
    Daly City
    Re: 2000 s4 problem
    thats a negative...
    -Chipped -DV -TBB -Catback Exhaust -Intake -Short Shifter -DTS -Boost Gauge -Turbo Timer -CF Hood -Springs -20% Tints -CC -Red Calibers -Smoked Tail Lights -12" Sub
    Mar 11 2008
    san diego ca
    Re: 2000 s4 problem
    You would also need to put in money outta your own pocket. Because if they do replace your turbos its gonna be turbos and turbo feedline if there smart enough.
    Jun 20 2007
    Colorado
    Re: 2000 s4 problem
    Does it still spool up and everything? Smoke out of the exhaust?
    I remember when I got my s4, tried to shut the car off and something kept going and grinding. Turns out the damn starter kept going, and soon left me stranded! hahaha
    Mar 11 2008
    san diego ca
    Re: 2000 s4 problem
    How much did you get it for?
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    it still spools up fine, no smoke out of the exhaust i just popped the hood and stuck my head back there and smelled a burning and i could see little waves of blue smoke when i backed up
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    $9800, its pretty much mint interior and exterior, clean carfax, new tires, timing belt and water pump was changed.
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: 2000 s4 problem
    Double negative. If they're generous, they'll give you the credit for the KO3's and you take it and run or find a cool shop that will install KO4's (under the radar) and pay the difference. Otherwise, you can definitely expect them to take the low road (read: cheap) and give you KO3's.
    Sorry for the tough break bro, keep your head up.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    so even though they still spool up fine you think they're just about to go
    Mar 11 2008
    san diego ca
    Re: 2000 s4 problem
    Go return it and just take the over the payments on mines. Mines have the timing belt done turbos are in great shape and its a stage 2+ i owe 13k and it has h&r coilovers axles were replace and cv boots i dont even want no money just take the payment over. It has 133k miles on it
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Re: 2000 s4 problem
    It's probably your valve cover gaskets that are leaking oil onto the manifold and it is wafting up the back of the engine. Turbos going bad will not show you without a sound out the exhaust (whistling) or oil out the pipes. Good luck.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: 2000 s4 problem
    Quote Originally Posted by s vier View Post
    Quite the optimist you are!
    But yeah, that's possible.
    08 S4- Stock SOLD
    Feb 09 2007
    00 S4
    MA
    Re: 2000 s4 problem
    ^^^that happens extremely often, its happening to mine right now.
    but there is no grinding sound associated with it.
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    Re: 2000 s4 problem
    yeh but the grinding sound could be the sound from so much shaft play in the turbo(s) plus your see blue smoke so
    10 b8 s4 6MT sprint blue / black & silver
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: 2000 s4 problem
    Quote Originally Posted by VinNyS4 View Post
    Or, it could be two seperate issues. I think we need a better explanation of "strong grind".
    08 S4- Stock SOLD
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    hard to explain i just notice it at random times lasts for about 2 seconds. I just got my car scanned for the check engine light and the code P1113 came up (fuel/air metering) was what it said. Could this be an air leak?
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Re: 2000 s4 problem
    You should check more into it. It could be the VCG leaking or the cam chain seal leaking onto the exhaust and making it smoke. With the miles you have on the car if the turbos havent been replaced they will go out soon if they havent already. Take it back to the dealer and have them check into it.
    Your check engine is for the MAF sensor. The sensor that is located on the air hose going into the air box.
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    Re: 2000 s4 problem
    Quote Originally Posted by 2ndEngineS4 View Post
    +1 for that idea....exactly what I ended up doing after 5 months of fighting with the dealership while they were "repairing" my car, in reality they ended up causing 2800$ worth of repairs that needed to be taken care of on top of the turbos/intercoolers. I took the 6g they were charging me, and the 2800$ and bought k04s and had a buddy help me put it all in
    Go take your car to an audi dealership have them take a look at it diagnose your problems then get an est for the repairs they tell you to get. take it back to the dealer you bought it from and go from there, Id tell your dealer you obviously dont want them to work on your car if they hadnt taken care of the repairs already or knew they existed.
    '00 Nogaro Blue S4
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    my check engine light turned off yesterday and hasnt come on since. should i still send it back to the dealer to get the (P1113) code checked out or can they only do something if the check engine light is still on
    Oct 31 2005
    Ashburn
    Re: 2000 s4 problem
    If my mind serves me correct P1113 is a Bank 1 Sensor 1 o2 sensor code.
    But i could be wrong.
    - Instagram: @Sinister_rs5-
    May 11 2008
    2000 audi s4
    Re: 2000 s4 problem
    yeah thats right but could i just tell them that i scanned the code and it was P1113 and they should check it out or can they not do anything because the check engine light is gone
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: 2000 s4 problem
    1 Fault Found:
    17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
    P1131 - 35-10 - - - Intermittent
    i thought that was the o2 sensor fault code... thats what i got when i vagged my car the other day... it was a hidden code.
