Results 1 to 12 of 12
Thread: remove calipers
    Registered Member One Ring TripleCS4's Avatar
    Oct 21 2008
    Agoura, CA
    remove calipers
    anyone know how to remove the calipers on an Audi S4 B6
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: Pulled over for no reason last night.
    not sure the point of this post, so you fought with a cop and ended up getting a tint ticket? sounds like oyu lost
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Re: remove calipers
    It's real simple. Pop the spring clip out and in the back there are two 7mm hex bolts. They have plastic covers so you will have to take those off first. There are two more bolts for the carrier.
    Mar 09 2005
    Santa Clara, CA
    Re: remove calipers
    LOL at edit, you're a dumbass dude
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Re: remove calipers
    I knew I should have taken photo's the last time I did this so I could post it up. Really though Triple, it's very easy to do. You'll see once you get in there.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Veteran Member Four Rings V8S4Fun's Avatar
    Jul 21 2008
    05 S4, 95 Jetta
    Taneytown, MD
    Re: remove calipers
    yes, very easy, you may need an air gun though
    [email protected]
    2005 Silver S4
    RAI Supercharged
    Unitronic Tuned
    JHM L/W Crank Pulley
    Custom 2.5" catless DPs w/Milltek Non-Res
    Sep 23 2006
    Houston TX
    Re: remove calipers
    Quote Originally Posted by V8S4Fun View Post
    nah, breaker bar and a BFH will do. Okay, maybe some PB blaster too.
    Established Member Two Rings kerlow66's Avatar
    Jun 26 2007
    02 S2000,05 V8 touareg,Duc749s
    los angeles
    Re: remove calipers
    This should help.
    http://www.audiworld.com/tech/wheel137.shtml
    Tech Article Title Author Date Front Brake Pad Replacement (B6 S4/B7 All) AlanL 2004 Please note right up front - if you have never done brake work before, STOP and go find a friend who has a clue to guide you through the task. Brakes systems aren't terribly difficult to learn to work with, but if you screw up the consequences can cause bodily harm to yourself and/or others on the road.
    The first task is to remove your wheel to access the brakes.
    The first task was to remove the retaining spring that holds the caliper arm in position. To remove the spring, use a screwdriver to get between the clip on the brake pad and the bottom of the retaining spring. Push up on the screwdriver blade and then pull towards you to get the locking tab of the spring to disengage from the clip:
    This will leave the spring in place, but with the locking tab out of the slot in the clip:
    Use a flat blade screwdriver to pry out the end of the spring arm. Use 2 hands with one positioned to keep the spring from flying across the room once it's released. I am using my other hand to take the picture in this shot.
    Next, spread the calipers to get some play around the pads. Hint - open the cap on your brake fluid master cylinder so the fluid can go back up the lines. If you move the pads a lot, fluid can spill over the top of the master cylinder reservoir.
    Use 2 screwdrivers - one on each side of the caliper. Kinda hard to show that and still shoot the picture.
    The next task is to remove the 2 bolts on the backside of the caliper that hold the caliper in place so you can access the brakes inside. There are 2 plastic dust caps the cover 7mm Allen bolts shown here with the red circles. If your car is not on a lift, you can use a mirror to locate these bolts:
    Once you pull the bolts out, you will find that you can lift the caliper off of the rotor and you have full access to the pads for replacement. You may find it helpful to have something like a paint can handy to hold up the caliper while you change the pads as shown in this picture:
    You will probably need a brake caliper spreader to push the brake piston far enough in allow the new pads to clear the rotor. This tool is readily available at many auto parts stores.
    The OEM pads in their full glory of grime:
    A good shot of the pad wear sensor wires getting close to breaking the circuit and triggering the dashboard warning lights:
    The final task in removing the old pads is to disconnect the wear sensor connector. First remove the connector shell on the far side of the mounting bracket and then use a small screwdriver to dislodge the short arm extending down on the mounting bracket. Twist the pad connector and it will come out of the mount bracket.
    Once the new pads are in, slide the caliper back over the rotor and replace the bolts. slide one end of the retention spring under the arm of the caliper and then position the tab of the retention spring behind the lip of the brake pad clip.
    Next, depress the other spring arm and push it into place.
    Finally, use your thumb to push the retention spring tab back enough to engage the slot of the clip:
    Your final view of the caliper should look like this:
    That's it! Replace the cap on the master cylinder and have someone pump the brake pedal until it starts to get firm again (it will sink all the way to the floor for a couple of strokes). Refill the master cylinder with enough fluid to reach the fill line and replace the cap.
    Established Member Two Rings dvandentop's Avatar
    Jan 01 2008
    South Dakota
    Re: remove calipers
    is it the same process for the rears?
    Derek
    2006 Z06
    2009 cts-v
    2012 S4
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Re: remove calipers
    since were on brakes here. Has anyone installed that brake pad clip with the S4 logo on it. Does it fit correctly. I see that its alot beigger than factory clip. and the caliper is cut out for the factory clip. But has anyone used the S4 logo clip without any issues ??
    Veteran Member Four Rings todd1010's Avatar
    Jun 17 2004
    Jacksonville, Florida
    Re: remove calipers
    Quote Originally Posted by chaos2984 View Post
    I've been using it on my B6 S4 brakes since the B7 S4 brakes came out without any issues. I thought there might be but it works just fine.
    Jacksonville's Premier Paintless Dent Removal
    Got A Ding? Give Us A Ring!
    904.705.DING (3464)
    http://www.dent-technique.net
    Sep 18 2009
    new york
    Re: remove calipers
    My friend used a it and it worked fine. She recently got it from the Los Angeles Auto Parts. the tools needed are there also there.
