Results 1 to 30 of 30
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    South Bend SS 8 Puck Clutch
    Here is my new South Bend 8 Puck SS clutch. It uses the same center as the OFE or FE but has the 8 pads instead of a solid disk and it is also made out of ceramic instead of organic or feramic like the OFE and FE.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Feb 17 2005
    Sarasota, FL
    Re: South Bend SS 8 Puck Clutch
    It would be more helpful on the car no?
    Apr 24 2005
    E55 AMG, CTS-V
    It just got here! Geez. I am gonna need help lifting the tranny back in anyway. Kinda sucks doing that stuff laying on the ground under some jack stands.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What pressure plate are you running?
    OEM DMFW?
    I forget your set-up. Thanks!
    I don't know how you guys do this without a lift. I am so spoiled doing clutches with a car lift and transmission jack.
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    yes oem flywheel that has been resurfaced 3 times now. Hell it might be a lightweight now
    ~David~
    CTS-V 9.6@148
    Jan 25 2006
    A4 2.0T
    MD
    Those pucks like tiny as hell....
    I look forward to the results..... but I guess no launching for another month or so huh - sucks.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    SS pressure plate?
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    SS with Eurocode mod.
    And yes I thought the same thing about tiny ass pads.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What is the 'Eurocode Mod' ??
    -Doug
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    let us know how it does.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    Looks like my clutchmaster 8 puck. Break in period is very short on ceramic clutches. Mine works great fwiw
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
    Apr 24 2005
    E55 AMG, CTS-V
    little stiffer
    ~David~
    CTS-V 9.6@148
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by A4 TSCHUSS View Post
    little stiffer
    The pressure plate?
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Aug 26 2005
    You can rent a transmission jack for cheap. With the trans strapped to the jack table, the table is adjustable for angle for/aft and side to side, and with the angles just right, the trans will bolt up perfectly, by yourself, without a struggle. The only thing to consider is that the car will need to be high enough for clearance to roll the trans jack with the trans strapped on it, under the car.
    Apr 24 2005
    E55 AMG, CTS-V
    what else would be stiffer?! Yes they do something like a different pivot point or something and it clamps a little harder.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Must be stiffer springs or something of that nature.
    -Doug
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    The Eurocode mod adds 800 more pounds of clamping force via relocated pivots.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    So what's the deal with these "puck" clutches? Looks like less surface area to grab.(I don't have clue)
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Quote Originally Posted by manhertm View Post
    Better heat transfer due to less material.
    Were you compensated for the FE since you were compensated with that because of the OFE, lol?
    -Sami-
    Apr 24 2005
    E55 AMG, CTS-V
    think you meant "were" not where. That threw me off a little but yes it was free.
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    nice, looking forward to the review
    Some fast things and some slow things
    ~Josh~
    Feb 19 2007
    Charleston, SC
    Damn! One of my biggest pet-peeves too
    -Sami-
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Well there has to be a trade off, cause all manual car would have this. So what is it?
    Mar 21 2006
    Lakeland, FL.
    Ceramic grabs and is able to withstand heat much better. The pucks are smaller to offset the grabbing ability, if they were bigger the clutch would be on/off and suck to drive.
    I'm back bitches!
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Looks good David, cant wait to hear how it works once you get it in and start launching the piss out of it.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    There is a reason why your dinnerware is ceramic....
    -Doug
    Jun 13 2005
    Audi
    To make it go faster?
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Buncha motorcycles
    Memphis, TN
    yes, puck clutches are more "grabby" and like dirty explained part of the reason they are pucked is because of the material. also they wont last as long as a traditional disk (less material)
    there are lots of things cars should have but your average driver doesnt want the trade off in driveability
    you are telling me! i tried to use a tranny jack to put it back in but said the hell with it and got under it and shoved it in.. much easier IMO
    my abs look much better after doing my clutch
    APR Stage 2/AWE Intake
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by actlsub9 View Post
    Win.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Exanimas View Post
    Win.
    haha.
    -Doug
