Results 1 to 40 of 49
    Senior Member Three Rings G-Bus's Avatar
    Aug 25 2008
    Montreal, Canada
    Just installed a Forge DV and...
    ...Theres no sound. I don't get it.. Is it supposed to sound the same as stock? My friends A4 has the same one and it makes a nice sound when he realeses the throttle.
    I guess this is 120$ down the drain... and I broke my OEM DV when I took it out too so I'm stuck with this one.
    Veteran Member Three Rings 04TurboB6's Avatar
    Feb 17 2008
    Leesburg, Va
    Re: Just installed a Forge DV and...
    well....
    if you put in reverse...you can hear it much more...
    try getting an intake...you will definately hear it...
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    you need an aftermarket intake to really hear it.
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Aug 25 2008
    Montreal, Canada
    My friends A4 has the stock intake tough.
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    I have a Forge Splitter which can go full recirc/hybrid/full bov..It has about 300miles on it. I will trade you for your 007(hopefully) +cash. LMK
    The valve retails for $175 new
    Quote Originally Posted by G-Bus View Post
    Maybe he is flashed? more boost means louder DV
    another stereotypical Audi
    Aug 25 2008
    Montreal, Canada
    Quote Originally Posted by a4wd View Post
    He is flashed but THAT much louder?! I can't hear sh!t.
    How much more do you want?
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    If your friend is flashed with software, it is a big difference. Running and building more boost than you
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    same DV? its a long shot but did you end up installing it backwards? some DV can be installed in the reverse order
    2006 600RR
    my photos
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    which color spring is in it, there are different tentions and the one you installed may have a spring that is too strong to allow proper function, I think the range is as follows (from memory)
    blue 23-25lbs boost
    green 15-20 ish
    yellow 8-9 approx
    see this first, then you can change the filter you have, but this may be the issue
    Aug 25 2008
    Montreal, Canada
    Well I checked on the paper that was included in the box and I fitted the right color spring for my boost. Assuming I run 9 - 12 PSI Stock. It cannot be installed in reverse? Theres a neck that is longer, a shorter one a small "nipple" for the vaccum. I installed the long neck facing downwards, the short neck facing the driver side of the car and the vaccum on the right side.
    It's a Forge DV 007
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    I wouldn't consider it a was of money. It always good to have a aftermarket DV.
    Aug 25 2008
    Montreal, Canada
    Well, air intakes don't give anything to these cars so I won't spend anything on that. Apparently only chipping it will make it sound louder..
    Thing is I tried the 5 hour test from REVO and I wasn't impressed at ALL. Everyone on here says it becomes a new car and everything. I guess I set my hopes too high because I really wasn't impressed and decided to not do it right away.
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    If you bought your DV to make noise you bought it for the wrong reason.
    789whp
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    if you want noise i'll trade you my 004, it's pretty loud
    two thousand two audi a-four quattro five speed
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    cheap'o cone filter.
    lol revo , the guys at the shop i took it to recommended i atleast try the trial.. ended up blowing one of my coil packs before i even left the parking lot.
    2006 600RR
    my photos
    Aug 28 2007
    You can drill a bunch of holes in your air box. that might help
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    i have a carbonio intake,stage 1+, and a 007 DV installed in reverse and its damn loud IMO, but not annoying loud !
    If i were to let off at 9 psi, id barely hear anything, even with the intake...
    Jul 27 2004
    Bay Area 925
    go stage 1+ and get a TP...it should resolve that issue for a lil bit..
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Quote Originally Posted by Howard Hughes View Post
    x2
    I'm APR Stage 1 with a Forge 007, and I don't hear a thing, nor do I really care to. Get a blow off valve if you want noise.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    I installed that same DV but along with Revo. When my friend and I took a ride after installing it, I could hear and feel noticeable differences. Sometimes I dont really hear the effects of the DV, but other times I do. Like someone mentioned, there is a huge difference between using it on stock vs chipped car.
    Here is what I would do if I were you:
    1. Try another Revo dealer, maybe he did not put you the right software or something did not go right with the trial. The difference between Revo chipped and stock should be like driving 2 totally different cars. One on steroids and the other all natural.
    2. Make sure there are no boost leaks.
    3. Try again.
    I have a stock DV if you want to use it send me a PM.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Its not money down the drain - you can hold more boost now with no worries, also if its just a DV and not a hybrid or a full BOV then you won't hear the sound unless you do a K&N filter intake (basically put a cone filter on your MAF, obviously with a heatshield.) Then you'll get the sound. I got ALOT more sound when I didnt have the heatshield at first because I didnt make it yet, but i'm not gonna take it off and heatsoak just for sound lol you can still hear it just not as loud with a heatshield.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Aug 25 2008
    Montreal, Canada
    I was looking on youtube last night and I checked out a few videos with 1.8Ts and Forge 007s and they all made the pshhht sound. I'm not talking STI loud pshht but just something you can hear. In all the videos it's making a sound, probably all chipped too but mine just doesn't make a sound at ALL. lolll For now, it's for sound, I know it's my rice side but it's just hilarious seeing peoples faces when it makes the sound.
    Jacky, we should reach cuz last time, I didn't hear your car make any noise.. lOL
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    If you bought it for the sound then you need to trade in your car for a civic.
    Remove the entire air box all the way to the turbo. That should give you the sound your looking for
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Aug 25 2008
    Montreal, Canada
    Ohh comon guys stop with the rice comments, it's a nice little sound that makes people have epic faces.
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    ^ you could try pulling the sound foam from the intake box.
    & since when did civics ever come turbo'd , blow off isn't rice
    2006 600RR
    my photos
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Yep coz I did not have the Forge DV installed at that time. Check your PM
    Jul 27 2004
    Bay Area 925
    Ok here are things you can do:
    1.) chip it with 1+
    2.) buy a bov
    3.) get a cold air intake
    easiest and cheapest way to get sound?
    Option 2
    Mar 11 2008
    Arizona
    Bought a DV for sound? You don't think that's a little ridiculous? Well, to each his own. What was wrong with your stock one? Did you REALLY get it just for sound?!!
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    even a TP should help. Cause i have a TP and nothing else except for a simota intake (which i plan to replace for the stock airbox) and i have a hyperboost DV. And i can hear my DV make what one of my friends referred to as a "breathing" noise, and if i hold the gas down a little more and build up more boost it gets louder. It's definitely noticable, and in comparison to my friends passat wagon 1.8t, i can't hear anything in his car at all.
    May 21 2007
    Florida
    why hasnt anyone let him know the 007 isnt made to produce sound like he wants? you baught the wrong DV if you want sound. should have baught a forge splitter or another hybrid valve.
    2018 Navarro Blue Q5
    Jul 04 2008
    Seattle, Washington
    ^^ people already have told him buying a DV for sound isn't the way to go.
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Get rid of boost reservoir. Put 007 in reverse. Get an intake. Move DV from stock location.
    Those will all get you the sound you want,
    but only if you boost much higher, lol.....
    Mine is loud as fugck in reverse. When it is in normal position, it makes no noise at all.
    My 2004.5 APR Stage 3+ is SOLD
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    hyperboost dv + carbonio
    i had nothing better to do after work
    http://www.imeem.com/people/H4j2QV/m.../untitled1mp3/
    2006 600RR
    my photos
    Aug 28 2007
    Quote Originally Posted by rxrep View Post
    Where is he going to move it too?
    Aug 25 2008
    Montreal, Canada
    So you guys are saying I should install it backwards?! Isn't it going to damage anything or give me a CEL?
    Anyhow, I am not going any further than this... I'll just Unitronic chip it and thats it. Again, I don't want BIG sound just a small "pshhht" when the car is pushed. I just came back driving my friends car and when he is driving normally, there is not sound whatsoever only on hard driving and thats exactly what I am looking for because the sound gets annoying if its going to be there every time you let off the gas.
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    i have the 007 and stg 1 revo and its loud but i have an sps3 and mess with my timing but im not sure why others dont hear a thing . .
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by J-jizzle View Post
    Wherever. Mine is up near the top plugged directly in to the turbo inlet pipe. Makes for easy access to service the valve or flip it from normal to reverse depending on my mood or how many high school kids will be wherever I'm going, lol.
    They don't care about much, but if your car goes pssssshhhhh, they think it's phat as hizell, yo.
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    When I put my forge splitter on my car it was otherwise stock and I could barely hear it. It sounded good when I was tuning it but once I put the belly pan back on it was bye bye sound. Since I got mine chipped though it sounds much better, especially from second to third. If you want more sound and a little performance, get a carbonio. If you want more performance and a little sound get it chipped. Or just rip off all the plastic under your car.
    Stretched, poked, and slammed.
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    When I had mine in reverse I could hear it.... which supposedly is the "correct" way?....
    789whp
    May 03 2008
    Orlando
    this is directly from Forge's installation PDF:
    Although the valve can be fitted
    in either orientation, I would
    suggest that you fit it, THE
    SAME WAY ROUND AS THE
    ORIGINAL BOSCH VALVE.
    Recent tests have proven this
    gives a far quieter operation.
    /thread
    Kevin W.
