Results 1 to 6 of 6
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Update: Headlight Adjustment Tabs
    After taking the headlight off, I noticed right away one of the tracks on the white adjusting wheel broke off, meaning everytime I would turn the adjusting screw to turn it it would pop out of track if I didn't carry enough momentum turning it. Anyways I managed to pop it back on track and for the most part it stay on track if I carry the same momentum while turning it.
    Also, you can override this by getting some small pliers and turning the white wheel manually.
    Thanks,
    Nick
    Original Story:
    Last Night I went out to aim my headlights. After tinkering around with the driver's side, I proceeded to the right headlight.
    I started to adjust the lateral adjustment screw and after I noticed that the adjustment screw was turning, but the white aiming wheel did not.
    Today, I inspected it in daylight and noticed that the fins on the adjustment screw that turn the wheel were stripped. Is there a way I can pop the adjusting screw out and replace it so I can turn the wheel...
    Here's a pic from a fellower AZer: Can the object in red be swapped out? That's the only thing stopping me from adjusting the white wheel.
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Re: Headlight ? w/ picture...please help
    damn I guess know1 has an answer...
    I guess tomorrow I'll just take the headlight off and inspect if I can replace it or rig it for it to work. Seems like the adjusting screw acts as a worm gear to turn the actual adjusting wheel.
    If not, I'll just get some ebay ecode reps
    AKA: masterforu2nv
    Current Mods:
    Aug 26 2005
    There is no way to disassemble the adjusters, to do so, requires destroying some of the adjuster parts.
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    From what I understand, doesn't the white wheel actually move the lense? All the adjuster screw does is moves the white wheel so that it can adjust...I hear what you are saying, but there's nothing wrong with the actual adjusting mechanism, just screw that spins got stripped, so therefore the white wheel can't move if the adjuster screw doesn't do its job.
    AKA: masterforu2nv
    Current Mods:
    Aug 26 2005
    Quote Originally Posted by pOrKcHoP07 View Post
    Yes, I understand your problem, You can drill out the small stripped bevel gear that normally drives the adjuster screw, but then slots will need to be cut into the larger white cap on the adjuster screw body, to turn the adjuster assembly. The problem with that is there is very litte clearance behind the adjusters with the housings installed, so it will be difficult to access the adjuster for beam adjustement.
    Remember, when adjusting the verticle beam elevation, BOTH adjusters are turned equally, for lateral beam position, only the outer adjuster is turned.
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Gotcha. We'll see what happens. Thanks for your input.
    AKA: masterforu2nv
    Current Mods:
