Results 1 to 14 of 14
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    door light issue
    Seems like everybody had or still have that problem but there is not an actually solution to it. I've searched everywhere. When i open front passenger door there is no indication that its open, no door lights nor the interior lights are working, cluster doesnt even say that door is open. Other three doors are working fine. How can i fix that? i found somewhere that i have to replace entire locking mechanism but why if it locks the door, gotta be some kind of wiring to sensor or something else is wrong. Any ideas??
    Registered Member Three Rings VagStaR's Avatar
    Oct 03 2008
    04 A4 tqm. 99 saab 93 2.0T 5sp
    York, PA
    Re: door light issue
    I know this won't help at all, but I have the same problem. Only mine is with the driver door. The wierd thing is that it started immediately after I took my car to audi to have the window regulator and gangswitch replaced. So I think my tech broke it.
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    i've seen a thread on this somewhere... the sensor is actually inside of the locking mechanism so i think it'll be a bitch to fix...
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Oct 03 2008
    York, PA
    did you ever have any work done to that door before? Like I said I took it to the dealer for a window regulator, then I went back for the door light, turns out one of the connectors just wasn't hooked up. problem solved.
    Oct 08 2007
    Columbus, OH
    ok, thanks i'll check it
    Oct 08 2007
    Columbus, OH
    i need a new car just cuz of that light lol
    Jan 24 2007
    it seems like your passenger side door control module is bad. door control module send operation information to central locking module. If you want to test the door control module i would uninstall it from passenger side & swap it out with driver side door control module. If driver side doesn't work you know it's the door control module
    Oct 08 2007
    Columbus, OH
    yeah, its the least of my problems right now, but thanks for heads up.
    Jan 24 2007
    Quote Originally Posted by BOPOH View Post
    No problem at all. Hope every things work out, good luck
    Senior Member Two Rings mlchael4's Avatar
    Jan 12 2009
    '02 A4 1.8t Sport Package
    West Burbs, IL
    I guess I'm bringing this thread back from the dead...but has anyone found a solution for this?
    Last night the sensor for my pass side door apparently stopped working.
    Drove half way home with the passenger side door half way closed.
    Mike
    Oct 08 2007
    Columbus, OH
    its got a mind of its own now, it works whenever it wants.
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    This is similar to the MKIV door latch microswitch issue. Over time, heat and cold cycles, and vibrations, the solder points on the microswitch crack and fail, and the entire latch assembly needs replaced, or you can open it up and re-solder all the points on the microswitch.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Senior Member Two Rings scoTT la rock's Avatar
    Jun 19 2007
    13 Q7 + 64 Impala SS 327/300hp
    jersey
    yep i had this problem in my audi TT. its a common problem in the TTs and i would imagine it happens in VWs too... the door switch is in the latch assembly in the TT and you have to replace the entire latch assembly to fix it. someone on audiworld once posted a DIY fix using a radio-shack microswitch but it seemed way too complicated for me to tackle it.... i dont know about the A4 yet though.
    01 TT 225 QC: RIP
    03 A4 3.0: sold
    06 A3 2.0T: sold
    13 Q7 Prem+: current
    64 Impala SS: current
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    Yea for the search function!! Can you guys tell me if my problem is similar to the OP's. when you open the doors there are two lights that should light up (botton and then a safety one up top) all the doors do this except my drivers door. Now i have the problem that if i lock the doors, i don't get the chirp and all my interior lights will stay on and the timer doesn't shut them off. I don't have any door open indicator on my DIS. I do have the code for drivers door control module not responsive. Any help much appreciative and can someone tell me where I can find the door control module? I ask because if I squeeze the wires in the door jam, sometimes the door lights will flicker and also my window switches don't work with the one click down/up, even if i reset it???
    || APR | BW K04-015 | ER FMIC | OEM S4/RS4/R8 Parts | '10 RNS-E | Hotchkis | Adam's Rotors | Podi | OCarbon | Euro Headlights | Euro Color DIS | Euro MKII TT MFSW | Euro Trunk | BBS | Vogtland Coilovers ||
