Results 1 to 9 of 9
    Jul 11 2007
    San jose
    headlight auto setting
    What are the things needed to have the car's headlight turn off by itself after you turn it off and walk away with it?
    obviously the switch is one of them, but what else? (relays, wiring, programming the ecu, etc)
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    Re: headlight auto setting
    what?
    Oct 08 2007
    Columbus, OH
    walk away with headlight??
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    He means is there a timer feature for the headlights for after you lock the car and walk away, that they turn off on their own.
    Oct 08 2007
    Columbus, OH
    isnt it called something like "homing feature" or something to deal with home? my buddy's car turn on fog lights when he locks the car at night(i think)
    Veteran Member Four Rings HP18's Avatar
    Jul 18 2004
    Orange County - CA
    yeah, some cars have the homing feature ..forgot which models did
    i know mine does...the fogs turn on when you unlock the car, and then when you lock it..they turn off after a while if your headlights have been on
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    It's the "Coming Home" feature that was available to those cars that had the Lighting package (Xenons). Only available on the 2004+ models.
    It also ties into the "Auto" headlight feature - to have them come on/off based on outside light conditions. That means you need a new light switch, the little on/off switch for the "Coming Home" feature, a light sensor that's near the center of the dash (up by the windshield), and probably some other items (relays, circuit board?).
    USP CLUB MEMBER #34
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    You can use a timed relay, 30-90 seconds whereby you tap power directly from a 12v constant source, and also tap into the headlight Wire.
    You will have to also tap into your alarm "armed" wire to trigger the whole event.
    This means though, that you will have the lights turn on for the preset amount of time regardless of whether you have your lights on or not, prior to shutting down.
    Though, this leads me to believe that you could probably tap into the headlight switch from the headlight "on" position.
    GL
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Jul 11 2007
    San jose
    A4 Moda, thanks, that works, is that how it's done from the factory though?
