    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Low pressure braking, squeek
    I'm getting a squeek from front breaks when i pretty on the brake peddle but very slightly. Any quick solutions to this? (this happens going fowards and backwards).
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Senior Member Three Rings Blarg's Avatar
    Sep 08 2008
    Kansas City
    Re: Low pressure braking, squeek
    Most likely some junk on the pad (brake dust, metal shavings, road dirt). Try washing them off or use some compressed air and see if that solves the problem.
    Sold - 2006 A4 S-line Quattro 6M Nav
    Nov 16 2005
    mass
    Wait until it gets colder... Mine always did it
    2003 RS6
    had: 2006 A4 quattro M6 2.0t
    had: 2008 VW GTI 2.0t M6
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    You've been around for a while... Haven't you noticed a thread exactly like this one comes up every week?
    The squeeking is normal. Here is a copy and paste from another thread. P.S. you were even the last person to post in this thread...
    This pretty much happens to everyone... I was told by my friend who is also a mechanic, that squealing and a good amount of dusting is usually a sign of a good performing brake pad material. It's probably just starting to happen to you because your pads are starting to bed. Bedding is when you develop a slight film on your rotor. This helps create more friction and better stopping power. I'll definitely agree with you that it sounds pretty awful and like something is wrong, but sometimes it's funny seeing people cringe when you pull up next to them. Haha although it can be kind of embarrassing because it sounds like you need new pads and are too cheap to buy them.
    http://www.audizine.com/forum/showth...ight=brake+pad
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Apr 14 2008
    Milton VT
    yea i'm being lazy today and dont feel like searching...i know it's an issue with our cars just seeing if there is a solution....it almost seems my brake power is less now than it was....might upgrade the pads.
