Results 1 to 23 of 23
Thread: Giac X
    Senior Member Two Rings A4-Achtung's Avatar
    Oct 01 2008
    2.8 B5 A4 Quattro
    Austin, Texas - Third Coast
    Giac X
    I have a 2001 A4 Quattro and ready to upgrade to a chip. I heard the Giac X is the most aggressive. But I cant find too much information on it. Can anyone educate me?
    2001.5 B5 A4 QTM - AVIC F700BT Mod'd 3.0 - GIAC-X Tune - Bailey DV36 - 3 in. TestPipe 2.5'' Back- Blacked Out Everything - 6000k DDM HID Headlights And Fogs - Slotted and Drilled Rotors - HAIL DAMAGE!!! -
    Established Member Two Rings Kaytek's Avatar
    Nov 19 2005
    Ottawa, Canada
    Re: Giac X
    Free edumahkation. Remember that local support is important if any problems arise.
    There's also this old comparison of GIAC-X and Dahlback.
    2001 1.8TQ Tip - GIAC X - Startup Racing Vogtland GTs
    Veteran Member Four Rings SFexBOY's Avatar
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    Re: Giac X
    My dyno #s from 2yrs ago w/ the X-chip. Nothing spectacular, but a vast improvement over stock.
    http://www.audizine.com/forum/showth...highlight=dyno
    '90 BMW 325i...SOLD!
    '89 BMW 325ix...SOLD!
    '05 BMW M3
    01.5 A4 1.8TQ (175K, owner since 4K)
    My cars.
    Dec 05 2007
    Re: Giac X
    The good thing about GIAC is that thier prices dropped $150 for thier stock tunes . A couple months ago and prior to, people had to pay $500. With that being said, GIAC def seems a good route to go. And another route is to find people parting thier flashed ECU's for maybe $450, so you can still keep your stock ECU when problems arise. I wish I had one right now.
    Oct 01 2008
    2.8 B5 A4 Quattro
    Re: Giac X
    Thanks for the info, I was trying to find out numbers and see if there is a diffrence in Giac's chips for 2001.
    Dec 05 2007
    Re: Giac X
    Rule of thumb:
    If you have a B5, go with either APR or GIAC (more favored). If you have an 01, go with GIAC or Dahlback (more favored). If you plan on going bigger than a GT2871r, go Unitronic or CTapp (route I took).
    Oct 01 2008
    2.8 B5 A4 Quattro
    Re: Giac X
    Thanks for that info.
    Senior Member Two Rings DSM 2 Avant's Avatar
    Jan 02 2005
    Re: Giac X
    GIAC now offers BT software for DBWs.
    http://www.giacusa.com/programs.php?mpid=265
    B9 S5 SB | B8 S4 | R.I.P. 2001.5 A4 Avant
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Giac X
    Rule of thumb:
    If you have a B5, go with either Unitronic or GIAC.
    .... If you plan on going bigger .... go Unitronic or CTapp
    Fixed.
    I <3 my Unitronic, and I will not convert. I currently work for a GIAC dealer as well, in my defense I bought my "tune" prior to my current employment.
    GIAC doesn't readily support BT/BAT tunes on anything <01.5 IIRC
    EDIT: GIAC is considerably cheaper than Uni, but Uni pro-rates your upgrades. Thus making the next tune for K04, GTRS, GT28, etc. cheaper.
    Registered Member Two Rings kingdon's Avatar
    Jul 07 2007
    new york
    Re: Giac X
    I have unitronic stage 2 and I must say I am happy with it. I drove a friend car with giac and my unitronic pulls stronger up stairs, trust me run unitronic stage 2 so when you are ready you can replace your cat with a cat deleted pipe and you will have no problem with your computer light coming on, plus what ever up grades you might need in the future unitronic has a program for it.
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    Re: Giac X
    I just got speedtuning's stage 2 software which spikes 20ish and holds 18. i ran my buddy with it to see if the 200 i spent was a waste or not. he has a 99.5 with giac, exhaust and front mount.. i have ST chip, exhaust and thats it.. we were neck and neck, in the long wrong i'd start to pull.
    def a viable option to look at going if you dont see the need to go broke for a tune.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Nov 22 2008
    Bergen County
    Re: Giac X
    i'm getting a 2001 a4 1.8t and i was wondering which chip is the best to get performance out of?? i was thinking unitronics or giac.. any suggestions?
    Veteran Member Three Rings kevin12's Avatar
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Re: Giac X
    Quote Originally Posted by rdiablos330 View Post
    Did you not just read the thread?! However Unitronic is the best performance wise if you ask me and others agree.
    Current:
    17 Ibis White A3 2.0TQ S-Line
    01.5 Santorin Blue A4 1.8TQ 5-Speed
    Uni 1+, XS Power Exhaust, ST Coilovers, Forge DV
    99.5 Laser Red A4 2.8Q Tip Totaled RIP
    01.5 Casa White A4 1.8TQ Tip Current Parts Car
    08 Ibis White A4 2.0TQ Tip S-Line
    Nov 22 2008
    Bergen County
    Re: Giac X
    Quote Originally Posted by kevin12 View Post
    I read the thread.. I like both and my friend says Giac is the best and most aggressive tune but I am leaning towards Uni and was wondering if anyone had anyy different thoughts
    Established Member Two Rings bbkid43's Avatar
    Sep 24 2006
    Minnetonka, MN
    Re: Giac X
    Using two DIFFERENT cars to compare chips is not a very good comparison. Anyone that has been around these cars for awhile knows there's a crap load of things that can affect your cars performance without you even knowing it. Examples being tiny vacuum/boost leaks, malfunctioning sensors, clogged hoses, etc...
    Honestly, i would go with a chip that you can buy locally if there is a knowledgeable chip dealer around. so you can have someone to go to if anything ever goes wrong and you don't have to deal with the hassle of sending your ecu out. In the end, there is only so much power to be squeezed out of the tiny k03. the difference between chips is usually minimal
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Giac X
    well said!!!
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    Re: Giac X
    whats this price drop everyone is talking about? The dealers around here are still selling em for 495
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
    Dec 05 2007
    Re: Giac X
    ^ I just noticed they bumped the prices back up. But maybe 3 months ago, they dropped the prices down to $350. Now, they are back up.
    Aug 22 2008
    Central Maryland
    Re: Giac X
    Fail :(
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    Re: Giac X
    Here is my APR Chip on my 01, At the time I had the same stuff as sexyboy:
    borla exhaust
    Balies dv
    Carbonio Intake
    stock smic
    161awhp 191awhp and it was warm day (this place was not a/ced)
    I found the chip pull's hard and made the car pretty quick. As fast as a stock S4.
    If your intrested im selling my Apr ECU from my 01 with three programs + ECU
    http://www.audizine.com/classifieds/...ct=5748&cat=20
    01.5 A4 1.8t sport
    Deactivated Four Rings
    Jul 16 2007
    2000 A4 Avant 1.9L BT
    Irvine, CA
    Re: Giac X
    Quote Originally Posted by djwimbo View Post
    Fixed.
    We offer trade-in as well. If you pay $495.00 for a k03 file and want to upgrade to K04 or big turbo, you receive that $495.00 as trade-in toward the new software.
    Our big turbo files for the 2001 are boost control enabled as well. As usual, they carry options for race mode, valet and kill (security mode) switchable via laptop (for non-CAN vehicles) or handheld switcher.
    Jul 16 2007
    Irvine, CA
    Re: Giac X
    MSRP on nDBW 1.8T software is $300.00. MSRP on DBW vehicles are and always been $495.00 for the basic stock turbo software. You have to remember that despite them both being 1.8Ts, the ECUs are different. This means that they carry different development costs.
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Re: Giac X
    I decided on Uni and am pretty happy I did. Just a bummer about a week after being chipped, my clutch decided to start slipping hard. Here's my dyno sheet. It was 162hp/205tq or so on a Dynomite, which reads a good amount lower than a Dynojet or so I've been told, similar to a Mustang. In comparison, a K04 PC-16 AWD pulled 170/220 and a stage 3 S4 pulled 290/290.
    Mods were test pipe, carbonio v2, apr cat back.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
