And the fight begins...
So, after getting my driveshaft cv joints replaced, the car was running smooth so I floored it on the way home. started accelerating hard, then felt like it hit a wall. Had to limp it home, ended up discovering one of the pipes blown out of the tbb.
Put the pipe back in, and the car seems to be running good. On the way to work yesterday, ended up next to a co-worker of mine who has a nice Caddy, and he decides to race ahead. I hit the gas, and the car stumbled, so I let off. Find out if I try to accelerate more than real lightly, the car has no power at all.
I figured this was a good time to try out my new Vag-com. I have no CEL showing, but I hook up the vag and do a scan. I get the following:
Address 01 -------------------------------------------------------
Controller: 8D0 907 551 A
Component: 2.7l V6/5VT G02 0003
Coding: 06611
Shop #: WSC 06325
10 Faults Found:
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-00 - -
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-10 - - - Intermittent
17880 - EVAP Leak Detection Pump: Short Circuit to Ground
P1472 - 35-10 - - - Intermittent
17938 - Camshshaft Timing Adjustment: Short to Ground
P1530 - 35-10 - - - Intermittent
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-10 - - - Intermittent
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-10 - - - Intermittent
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 35-10 - - - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00
That's a lot of "Short to Ground"s.
