Results 1 to 31 of 31
    Senior Member Three Rings vc1492a's Avatar
    May 04 2008
    Knoxville, TN
    help! water leaking into rear headliner! (Pics Added)
    im at school, and need help! found water dripping on my rear seatbelts. the headliner on the c pillars is soaked... help me :(
    2010 A4 2.0T S-Line Cab (CVT)
    2004 Stage 2 Mini Cooper S
    Sold: OEM+ 2005 Audi A4 USP 1.8T
    Registered Member Two Rings
    Jun 23 2008
    Orange, CT
    Re: help! water leaking into rear headliner!
    im in the same boat, no one ever responded to my thread
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    My car does the same thing after a car wash......the rear sunroof drain tubes are clogged.
    You need to find the tube(s) were it drains from (which are near the rear bumper....which I think you have to remove), and the blow compressed air up through the tube....
    -Sami-
    May 04 2008
    Knoxville, TN
    thanks. how do i go about getting to the tubes? water drains fine coming from the rear window. are there different tube drains for the sunroof and the rear window?
    Feb 19 2007
    Charleston, SC
    There is a drain tube at EACH corner of the sunroof.
    2 at the front (running down each A-pillar)
    2 at rear (running down each C-Pillar)
    So that is 4 total.
    I think you have to remove the rear bumper and from there you will see a rubber brown hose and use compressed air
    -Sami-
    Dec 06 2007
    u could also feed a thin insulated wire through the the top it'll push it all out.
    -Kirk
    BetaAlphaTau Member #58
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by AudiA4Turbo22 View Post
    hey bo! taker your smartness somewhere else
    -Sami-
    Dec 06 2007
    ^^ur just jelous my IQ is like 10000
    -Kirk
    Senior Member Two Rings fcamargo6thave's Avatar
    Apr 08 2007
    While u are at take the battery out and check to see if the drains in the tubes underneath the battery are all clear or else u will have water underneath the drivers seat
    Veteran Member Three Rings A4Avant02's Avatar
    Feb 05 2008
    '02 A4 Avant, '74 Triumph TR 6
    Folsom, Cal
    Take a look at this thread.....
    http://www.audizine.com/forum/showth...=Sunroof+drain
    I fixed mine by cleaning the sunroof drain lines and by replacing the gasket around the sunroof.
    Senior Member Three Rings ProJect_*A4*'s Avatar
    Jun 01 2008
    2011 BMW M3 Comp. Package
    open your doors, poor water down your drains that are in the sunroof corners. if water comes out fast and easy by your door hinges (B6) then you shouldnt have a clog problem.
    German Engineering
    May 04 2008
    Knoxville, TN
    Quote Originally Posted by ProJect_*A4* View Post
    tried that thanks! unfortunately, it looks like I have a clog problem.
    Senior Member Two Rings mlchael4's Avatar
    Jan 12 2009
    '02 A4 1.8t Sport Package
    West Burbs, IL
    Re: help! water leaking into rear headliner! (Pics Added)
    Is it possible to locate the rear drain tubes via the sunroof??
    The fronts are quite easy to find..but the backs are another story..
    Mike
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    It would probably be much easier to just pull the rear wheel liner and go at it from the other end. There are only a handful of screws retaining the liner and it comes out easily. Just look for the drain tube at the base of the "C" pillar. It was the B5 that required pulling the rear bumper to get to the rear drains.
    Jan 12 2009
    West Burbs, IL
    Will Do!
    Thanks,
    Mike
    Jan 12 2009
    West Burbs, IL
    A handy little diagram for anyone having trouble locating sunroof drain tubes.
    Mike
    Apr 12 2009
    Thread jack, and while your at it remove your doorblades and clean and inspect, doesnt matter if their stock or s4 or usp DO IT, could save a corrosion issue before it starts.
    Jan 18 2007
    Lexington Ky
    I thought you had to remove the headliner ? and clean the tubes or replace them??
    Veteran Member Three Rings 80CID's Avatar
    04 A4, 88 RX7 turbo, 12 MDX, 12 Grand Cherokee
    Houston
    be carefull using compressed air...it might pop the hose off from the nipple. I'm not sure how the hose is attached on the A4 but on my RX-7 its just a simple spring clamp.
    "No matter what everyone else says..I still think you suck!"
    -Bill
    Registered Member Two Rings A4B6's Avatar
    May 11 2009
    syc.
    Very nice!
    I have been looking for a soultion to this problem.
    Nice diagrams/images...
    Damn, I am glad I found this site.
    May 04 2008
    Knoxville, TN
    Quote Originally Posted by mlchael4 View Post
    hmmm... interesting... my drains go down my d pillar.
    Jan 12 2009
    West Burbs, IL
    Really...hmmm, that is interesting.
    Is that an image of the trim near the sunroof???
    Mike
    May 04 2008
    Knoxville, TN
    sure is
    Jan 12 2009
    West Burbs, IL
    Update:
    So over the weekend we got a considerable amount of rain...and wouldn't ya know it, another F'ing giant water stain.
    I am sick to death of cleaning these nasty ass water marks!
    So.. after drying and repeatedly cleaning the new & old water spots I pulled the rear passenger wheel liner to look for the illusive rear sunroof drain tube.
    No Luck!
    Upon inspecting I Do Not see the rear drain tube below the C pillar.
    Can anyone offer another suggestion?
    Does the rear bumper in fact have to come off to locate and clean these tubes??
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Old guy just told you to remove the Rear wheel liner.
    Have you tried that? The c pillar sits on top of the rear wheel. it would make sense that it drains out right there.
    So why don't you take a look at that first.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Jan 12 2009
    West Burbs, IL
    Quote Originally Posted by A4 Moda View Post
    Did you even read my post...??
    WTF
    Jun 11 2005
    In that case, I better get my eyes checked.
    I'm on my bb. I just re-read your post.
    I've pulled off the bumper and i haven't found anything that looked like a drain tube.
    honestly, I'm pretty confident that it'll be in the rear quarter panel man. I'd suggest you try the C pillar next.
    2003 1.8T
    Jan 12 2009
    West Burbs, IL
    Yeah.
    Shit, I guess I'll have to look again.
    I looked around in the front & rear side of the rear wheel well..behind the liner, but I didn't see any drain tubes.
    It must be tucked up in behind the sheet metal that forms the wheels well.
    The only drain tube I was able to find was for the gas filler overflow/drain.
    (But she's clean as a whistle now)
    Audizine on the BB FTW!
    Aug 14 2007
    2002 Dodge Dakoto 4.7L & a 1990 Honda Accord that won't die
    Bellevue, WA
    I don't see your diagram in your post. This is from Bentley....note that the instructions read to take the rear bumper off, but the diagram clearly shows them ending in the forward side of the rear wheel area. I bought a thin speedo cable from the auto parts store but found it impossible to get it into the drains from the sunroof side. I have yet to pull the rear wheel liners myself to go at it from that end. Using a flashlight and getting into the right position, you can see the rear drains on the sunroof side.
    Jun 11 2005
    nice pic, thanks AudiNaut for the graphic
    2003 1.8T
    Jan 12 2009
    West Burbs, IL
    AudiNaut:
    Yes, I had the same diagram posted earlier from Bentley..but as you said, it contradicts it's self.
    Diagram show at bottom of "C" pillar...but says remove rear bumper cover, so I don't have a clue.
    I did look behind the rear wheel liner, but as I stated above, didn't find anything.
    I will post an update possibly this weekend when I can inspect further.
