Results 1 to 14 of 14
Thread: Bi-Xenon issue?
    Established Member Two Rings will665's Avatar
    Oct 20 2008
    2003 A4 3.0
    Louisville
    Bi-Xenon issue?
    My Bi-Xenon's beam pattern looks something like this....is this normal... I know on euro cars they have that type of pattern but I feel that mine maybe a little out of wack. Ill post actual pics if needed.
    2003 AUDI A4 3.0 Premium, Sport, CW Pckg.
    Dec 06 2007
    Re: Bi-Xenon issue?
    u want that that's perfect the sharper the curvature the better
    -Kirk
    BetaAlphaTau Member #58
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    Re: Bi-Xenon issue?
    that's how it's supposed to be.
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Dec 24 2007
    New York, NY
    Re: Bi-Xenon issue?
    you have bi-xenons? unless you put bi-xenons in you probably have single xenons.
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Re: Bi-Xenon issue?
    I think it's designed so left lamp doesn't blind oncoming traffic.
    Veteran Member Three Rings dextrek's Avatar
    Aug 26 2008
    B7 S4
    Detroit
    Re: Bi-Xenon issue?
    does the auto leveler do this patter automatically? Cause mine seem to adjust to a flat line and I thought that was weird...(probably blinding the oncoming traffic.)
    -Ben-
    B7 S4 Dolphine Grey
    B6 A4 USP Moro Blue *Sold*
    Oct 20 2008
    2003 A4 3.0
    Louisville
    Re: Bi-Xenon issue?
    Quote Originally Posted by dextrek View Post
    yes
    Veteran Member Four Rings boravr6's Avatar
    Aug 14 2008
    09 CTS-V
    Ontario
    Re: Bi-Xenon issue?
    just curious how you test your pattern?
    ** Proud to support **
    JHMotorsports
    AUDI Revolution
    ~ 2009 Blue Diamond Tricoat CTS-V
    ~ 2006 TD1 Imola B7 S4 sedan 6MT *SOLD*
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
    Aug 26 2008
    B7 S4
    Detroit
    Re: Bi-Xenon issue?
    is there a way to adjust it manually to fix my straight line pattern?
    -Ben-
    B7 S4 Dolphine Grey
    Aug 26 2005
    Re: Bi-Xenon issue?
    Quote Originally Posted by T0M3K View Post
    The cut off shield profile is the same for both sides, and when aiming the beam angle, both sides are even horizontally, being set to the same verticle elevation.
    Aug 26 2005
    Re: Bi-Xenon issue?
    The Auto Leveling function has nothing to do with the cut off pattern profile. The pattern shown in the drawing posted is an E-Code cutoff pattern. The US DOT cutoff pattern is different, and is almost flat all the way across, with only a small step up mid way along the cut off line, and is a tad higher on the right half side of the cut off line.
    Aug 26 2005
    Re: Bi-Xenon issue?
    Quote Originally Posted by boravr6 View Post
    You lay out a test target on a wall, using 1" masking tape, with the tape placed according to the specified measured distances from the ground to the headlight center lines. See instructions for aiming headlights.
    See link: http://www.danielsternlighting.com/tech/aim/aim.html
    Aug 26 2005
    Re: Bi-Xenon issue?
    Yes, see linked information to adjust.
    Aug 26 2005
    Re: Bi-Xenon issue?
