Results 1 to 11 of 11
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Torn engine what to clean with.
    Im doing my stage 3, headgaskets and all kinds of things through the winter. I got my engine all apart and would like to clean it all up. I don't know much about chemicals and my question to you guys is. Is it safe to use brake cleaner to clean the oil pump, ect? I'm going to take the heads to the machine shop most likley so im not worried about them since they clean them up.
    What do you guys recomend to use as a cleaner?
    Thanks
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: Torn engine what to clean with.
    To clean any of the engine internals I recommend diesel.Brake cleaner is toxic (not like diesel isnt).
    My advice is to take it to a local sonic cleaner.
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    Simple Green is supposed to be all natural, and that stuff can clean.
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Feb 09 2007
    00 S4
    MA
    I've had good results with "foamy engine brite"
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Jan 03 2008
    Iowa
    If someone didnt understand what i was asking is what to clean the internals with? Crank oil pump and all the other litle things.
    I have some ENGINE BRITE in the shop but havent tried it yet. Simple green sounds like something that would work, I wil try both of them out and see what happenes. I don't want to use something that can be harmful to the motor.
    Oct 30 2006
    B8 A4 Avant 6spd
    Brake parts cleaner, just do it in a well ventilated area.
    -18 718 GTS
    Aug 06 2008
    Canadia
    to answer your question, yes its safe to use brake clean to clean the oil pump, just make sure you lube it up (pour some oil into it) before re-installing so it doesn't get a "dry-start" however, brake clean is very expensive and not very effective at degreasing. a drum of brake or carb clean is effective, but extremely toxic and will stink up a shop or your house very quickly, so for that reason i would recommend solvent, a 20L drum is cheap, its fairly low odor, and next to harmless with a air tight lid on it. (which it will come with anyway)
    for water based degreasers, I use super-clean, comes in a purple bottle, works like the cats ass, if you use it on internal parts, just dry the stuff off after with your air gun and paper towels. if your still worried about rust, spray some WD-40 on it after. to be safe.
    the B5 S4 is like the mafia... there is only one way out!
    Jun 01 2008
    Apopka, FL
    I'd go with diesel as well. It's cheap and removes virtualy everything in a short amount of time and with very little effort. It's the best stuff to use when you don't have access to acidic solvent.
    Jan 03 2008
    Iowa
    Thanks guys i also have some diesel in the shop so i can try that as well.
    Aug 06 2008
    Canadia
    as they say in Australia "put some doisel in that petrol engine! crikey!"
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by GetAwayFromMe View Post
    i used simple green on little things like to clean my engine covers, and you have to be careful, because its so strong some of it got onto the serpentine belt and the next day after a drive i had shavings of belt all under my hood... the dam simple green ate away at the belt! so be careful with anything rubber or plastic
