Results 1 to 7 of 7
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    Strange sound on deceleration
    There's a knocking. I can't locate it, but seems to be coming from the motor/tranny area. When the clutch is in, the noise is is made as the revs drop, or when my foot is off the pedals, car in gear (decelerating). I originally thought it was a control arm, but is definitely motor/tranny dependent.
    The car does have a LWFW, but I've never heard this before. Motor mount? Flywheel? I'm really at a loss here....
    Established Member Two Rings Hoxmarch's Avatar
    Oct 22 2008
    01 Nogaro S4 6mt <3
    Houston
    Re: Strange sound on deceleration
    It happens to me to. CV Joint / boot most likely
    Veteran Member Three Rings tbone5446's Avatar
    Nov 16 2006
    b5s4, 85 4runner T3/T4 turboed
    San Diego
    driveshaft
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Check to make sure your lug nuts are tight. I had a that happen on an old car.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 06 2006
    09 Subaru Outback XT, JD Tractor, EZ Go,
    Middletown, Ohio
    put on lift or stands and go around trying to reproduce the sound by hand
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Throwout bearing? mine was making noise and just went out. When i press the pedal it would have a whine.
    Dec 06 2006
    Middletown, Ohio
    The fact that the sound remains whether or not the clutch is in or out would lead me towards parts that are attached to the wheels first.
