Results 1 to 6 of 6
    - Clutchmasters specials to get your power to the ground! -
    You've made the investment for more power. Be it bolt-ons, software or whatever it may be. What good is that power you're making, if you can't safely or effectively put it to the ground without damaging your drive train. Clutch upgrades are must no matter what stage of modding you're in. Longevity is key.
    With that being said, we're proud to release special pricing for Audizine members on Clutchmasters clutch kits! Their staged kits are made to cater to whatever amount of power you're throwing at the street. From stage 1 and progressively on up, Clutchmasters has a kit for you.
    All Clutch Masters systems come complete with:
    -Pressure Plate
    -Clutch Disc
    -Throw-out Bearing (when applicable)
    -Pilot Bearing or Bushing (when applicable)
    -Alignment Tool
    PM me with your goals in power or what you're currently running HP wise, and I'll gladly price you out on a recommended clutch kit from Clutchmasters! Most Audi Clutchmasters clutch kits are IN STOCK and READY TO SHIP. We can also do flywheel/clutch combos, just specify if you're looking for this!
    Re: - Clutchmasters specials to get your power to the ground! -
    PM's replied
    Nov 19 2005
    Pair of (. )( .)
    bump for a good product...
    I've used CM for all my cars in the past, and now i have stage 3 in my 6, powerful stuff, doesn't matter how hard you drive and how hot outside it grabs like crazy.
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Thanks! These are definitely rock solid clutches.
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    My clutchmasters stage 3 kevlar lasted a whopping 6k miles and they would not cover it at all.. And shot you can pull some strings to have them cover it?
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Specials still active! PM for pricing details!
