Results 1 to 16 of 16
    May 21 2007
    Florida
    crank sensor replacement.
    just wondering how hard it is to replace a crank sensor? by the looks of the new sensor its just 1 screw holding it on and then the connector. i just dont know where it is/if there is any specifics to the job. anyone got a DIY or wanna quickly explain the low down for me? thanks.
    car is a 03 a4 1.8t quattro automatic if it matters. (not mine)
    2018 Navarro Blue Q5
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: crank sensor replacement.
    diy is up on a4mods.com
    -Doug
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    It's not bad at all.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    May 21 2007
    Florida
    hmm i looked on a4mods and didnt see it. guess im blind. ill check again. thanks
    May 21 2007
    Florida
    are the crank sensor and speed sensor the same thing?
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Quote Originally Posted by doublezero30 View Post
    no
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    May 21 2007
    Florida
    welll then i really dont see a write up on a4mods for the crank sensor then. haha
    Dec 03 2005
    2 pedals 1FG
    connecticut
    engine speed sensor (engine rotational speed sensor, rpm, etc..): http://a4mods.com/#index.php?page=we...eedsensor.html
    What do you mean by "crank sensor"? I thought you mean speed sensor. There are no other sensors on the crankshaft of the 1.8T except the speed sensor.
    Are you referring to the sensors in the transmission?
    -Doug
    May 21 2007
    Florida
    ^yea thats the diy i saw. sensor looked the same as what the dealer gave me. im really unsure. my buddy got his car vagged and told me he needed a crank sensor so i went to the dealer and got him one at my cost (wholesale). i guess they are the same deal. looks identicle
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Do you have the codes he pulled?
    I recently replaced my engine speed sensor and if that's the part you're referencing, wasn't too bad to R&R. Took me about 30-40 minutes.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    May 21 2007
    Florida
    nope, and i doubt he knows the code either. but a good shop told him he needed a "world pack crank sensor". i had never heard of it, but went to the dealer and asked for one anyway. got the same thing as in the DIY
    May 03 2005
    Boston
    interesting, never heard of that term either. If it's the same part as in the write up and has the same PN (should be written on the box as well as the sensor), hopefully it solves his problem.
    EPL S2 + TCU
    Previous Cars:
    May 21 2007
    Florida
    ^yea ill check that now. didnt even think of it. he's had his EPC light on and CEL and said sometimes its real hard to get it started. so sounds like this will solve the issue based on martini's writeup
    edit: yup same part number. ill do it up probably in the parking lot of NSDA's gtg on sunday haha.
    May 03 2005
    Boston
    cool. When mine went, I had the EPC and CEL light as well, not all the time but intermittently in the beginning then got worse. Car would stall when sitting at a light.
    EPL S2 + TCU
    Previous Cars:
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Sounds like just different terminology getting thrown around.
    Again, that sensor in the a4mods.com write-up is the only engine rotational speed sensor present on the crankshaft of the 1.8 motor. I do not know what else your buddy's problem could be unless the code is referring to the vehicle speed sensor in the transmission (for your speedometer).
    -Doug
    Established Member Two Rings Petabell's Avatar
    Feb 03 2009
    Las Vegas
    I've been having this problem lately.. EPC and CEL accompanied by random stalling, especially while the car is resting like at a stoplight. It's intermittent, happening usually once a day accompanied by limp mode. The codes i got are:
    P0321
    Ignition/Dist
    Engine speed input
    CKT Range/Perf
    P0322
    Ignition/Dist
    Engine speed input
    No Signal
    sounds like a bad crank sensor??
