Results 1 to 14 of 14
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    Camshaft replacement
    OK, so blew my turbos and am gonna go bigger. Been researchng like crazy and deicided that I'm gonna change my intake cams to 2.8 cams. I want to make sure I need the cams from an AHA 30v engine, right?
    I'm not asking whats the best cam, I'm just asking how hard it is to actually do. I'm having a machine shop freshen up the rest of the head, but they requested that I bring it in without the cams (???).
    This is my first time doing this and I would like to keep the screw-ups to a minimum. Is there a DIY write-up? or is the bentley the best option for that? Anyone with experience, please chime in.
    wrenching will commence in 3-4 weeks
    TIA
    Mar 21 2005
    2019 RS5 SB / 2025 SQ7
    RI
    Re: Camshaft replacement
    Stick with stock cams. You'll just lose low and mid range with 2.8L cams. Unless you have gt28's... you're not going to get anything from them.
    Even RS4 cams aren't worth the labor with K04's, stock intake mani and stock heads.
    May 18 2007
    Baytown, TX
    FYI... plans are to go single turbo, would like the addition on the top end.
    Active Member Three Rings panix73's Avatar
    Mar 17 2006
    Battleship Kruzer
    Long Island, NY
    If you haven't sourced yourself a set of 2.8L cams yet, let me know, as I have a set for sale. On just about any larger turbo setup, these will be beneficial as they'll provide a longer duration for time that your intake valves will be open, resulting in more air being able to be drawn into each cylinder and GENERATING MORE POWER!
    Although 2.8L cams provide a longer duration over the stock cam, I wouldn't use them WITHOUT THE COMBINATION of an adjustable cam sprocket for overlap correction. (http://www.034motorsport.com/product...ducts_id=14022)
    Innovate.
    May 18 2007
    Baytown, TX
    ^^ ok thanks. so, i need to put the adjustable cam sprocket on my exhaust cams in combo with the 2.8intake cams?
    Also, I have sourced a pair of 2.8 intake cams for $170 shipped. Can you beat that?
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Quote Originally Posted by RedRocketS4 View Post
    oooo nice details...
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    I swapped mine out with 2.8's, i took my cams out before i pulled the heads. I used nail polish and marked what link was on what tooth. Thats all. your going to need the special tool for taking the tension off the cam tensioner. New gasket for it and half moon.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    May 18 2007
    Baytown, TX
    Quote Originally Posted by Jung View Post
    Details aren't 100% yet, but trying to make 500awhp on pump. and looking at gt35r, but thats not the discusion here.
    Quote Originally Posted by S4 in_lowplaces View Post
    This is exactly the guy I need to talk to. Did you have to change anything else with the cams, valves, lifters, etc? Such as, using the adjustable sprocket from 034 as mentioned above?
    Jul 07 2007
    Tempe, AZ
    are you doing the work? or are you gonig along with deb38's single conversion
    Senior Member Two Rings SpoolPastYou's Avatar
    Jul 14 2008
    Miami
    ok question here..are the 2.8cams or rs4 cams not worth it in terms of the top end power you gain compared to low end torque loss...or do people say there not worth it because of the labor/install??
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    There is a set of RS4 cams on ebay for sale the guy selling them is from NY also.
    http://cgi.ebay.com/ebaymotors/Audi-...QQcmdZViewItem
    Jul 14 2008
    Miami
    yea i saw them..which made me curious about this question
    Mar 21 2005
    RI
    Quote Originally Posted by SpoolPastYou View Post
    RS4 cams aren't worth it because they don't do anything. I did back to back dyno pulls and I didn't gain any power. Maybe a few hp wayyy up top. But nothing to justify the cost or pita install.
    With 2.8's you lose a ton of low end. Not bad for turbo's with lag, because you gain a ton of top end flow. But with k04's you don't want to lose low end, and they can't flow enough up top to take advantage of them. I've also heard they are a bit hard to tune for.
    Jul 14 2008
    Miami
    Quote Originally Posted by Dr. Jekyll View Post
    thanks for the input..ive heard similar stuff too..they'd probably make more sense on like a rs6hybrid setup with 2.8 heads..in the other intake mani thread, im sold on the 1 from vast...im thinkin of buying a stock TB and sending it out to get ported too, my ko4's dnt taper to bad im only at 20lbs and theyll go down to 18lbs right close to redline..but i wish it'd flow through the high high ends a little quicker..
