Results 1 to 8 of 8
Thread: homebrew EFK
    Feb 09 2007
    00 S4
    MA
    homebrew EFK
    Im looking to make a EFK and need to know which SPAL fan to use:
    all I know:
    14" fan
    what I need to know:
    puller or pusher?
    CFM amount?
    better options than spal?
    hi flow vs. low flow? (SPP kit)
    TIA
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: homebrew EFK
    I have a SPAL fan, but I bought it through VAST. Its the "medium flow". I highly recommend it. It pushes SO much air behind there.
    Feb 09 2007
    00 S4
    MA
    Re: homebrew EFK
    yeah^^ I looked at the vast one, and the SPP one, just wanted to save a few bucks.
    I also need to know the size of the belt to delete the clutch fan altogether.
    Mar 20 2008
    Italy
    Re: homebrew EFK
    the stock belt will be fine.
    RS4 B5
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: homebrew EFK
    i was going to buy the fan seperate, but went with the Vast one instead. The price to do it by itself was too close to the vast price, plus the Vast one includes the cover for your timing cover. Exceptional service to add.
    Feb 09 2007
    00 S4
    MA
    Re: homebrew EFK
    Quote Originally Posted by andream88 View Post
    I was under the impression that you could rid yourself of the pulley all together, meaning I would need a shorter one. Like you can in the A4's.
    is there something the fan's pulley actually drives/does beside spin the clutch fan?
    Also, the Fans get pretty cheap on Egay.
    Registered Member Two Rings
    Jan 09 2008
    2001.5 s4
    Re: homebrew EFK
    Just watched a vast unit be installed a month ago. Even with getting rid of the pulley/fan/bracket, no new belt needed. I believe I remember reading that the vast hi-flow unit is in the 1800's cfm range. Most are reversable I think depending how you wire them. g/l
    Jun 14 2007
    2000 S4
    Connecticut
    Re: homebrew EFK
    Quote Originally Posted by ScottyT View Post
    VAST sells two kits as you mentioned.... the medium flow pushes 1900CFM, and the Hi-Flo for another 30 dollars is 2200 .
