Results 1 to 12 of 12
    Jul 30 2008
    audi s5
    New Jersey
    Audi drive select on s5
    I heard from the audi dealership if you add this option you will not be able to lower the s5.
    Is it true or not.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Audi drive select on s5
    From what I've read, if you are going to add coilovers then it is a waste to buy that system/option because it disables it. (I could be wrong though)
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    i think it's true that you cannot lower the car with coilovers if you have drive select, because drive select dynamically changes the dampening of the shocks.
    it may be possible you could lower with springs, but i'm not even sure about that.
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    Active Member Two Rings B42's Avatar
    Sep 19 2006
    Nagoya
    You can lower the S5 which has the Audi Drive Select system.
    The S5 which is sold in Japan has the ADS, and it's a standard equipment.
    If you wanna change just springs, you can install them like the H&R.
    You can use the ADS and will not get any warning message on the DIS.
    If you wanna change coilovers, you can install them also, but it's difficult a little bit
    because a shop who will install them needs some knowledge of the ADS.
    In Japan, only a shop can install coilovers to S5 which has the ADS.
    They kill just the function of the shocks, so other ADS functions like the handling and the engine still work.
    You'll not get any warning message.
    Sorry about my poor explanation
    All S5s on this photo have the ADS system.
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    ^^ very good point. it's not that it's not possible to do, you just can't use the drive select anymore if you replace the shocks...
    Sep 19 2006
    Nagoya
    Quote Originally Posted by toothysaw2 View Post
    The Audi Drive Select changes 4 thigs.
    #1.the dampering of the shocks
    #2.the characteristic of the steering
    #3.the characteristic of the transmission
    #4.the characteristic of the engine
    If you replace the coilovers, you can't change dampering of the shocks,
    but still you can change other 3 things which are #2-#4 by useing the ADS.
    I think that will depend on the shop which has knowledge of the ADS.
    Oct 09 2008
    Quote Originally Posted by B42 View Post
    Yeah but the most noicable aspect of the Drive Select is the shock dampering. If you get it standard that's one thing but I don't see the point of getting an expensive option only to do a mod which will render it's main function useless.
    Sep 19 2006
    Nagoya
    Quote Originally Posted by KiloByte View Post
    KiloByte, is this question with me?
    I think if I want to lower the S5, I should not get the Audi Drive Select actually,
    but I can't chose the S5 without the ADS because the ADS is standard equipment in Japan.
    That's why I do those things if I want to lower.
    Maybe you guys can get the S5 without the ADS in America, right?
    I can't get your point a little bit , so maybe this may not be an answer you want
    Jul 30 2008
    audi s5
    New Jersey
    I put my order in for a s5 in white with the red int. at end of july, the audi dealership told me, I still have time to change any option. I guess my best bet is to remove the ADS option so I can lower the car without any problems.
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    ^^ Yes and save your $2900 for coilovers. The only suspension mod to a car with ADS is springs only. You're just wasting your money otherwise.
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Senior Member Three Rings SupraBlur's Avatar
    Jul 16 2008
    Los Angeles, CA
    Just a note, as you you said #1 is cancelled out by getting coilovers. #3 is not applicable to 6MT cars. And #4 is just a change in throttle position sensor sensitivity, which can be had for $300 by getting the Sprint Booster.
    The only ADS feature not replicable as far as I know is #2, the adjustment of the steering feel.
    2021 Audi SQ8 - S Sport - Dragon Orange
    Previous Audis:
    2018 Audi SQ5, 2009 Audi S5
    May 13 2009
    Berkeley, California
    Question Re: Audi drive select on s5
    On the topic of ADS, does anyone know if any of the ECU chipping will work with the ADS? I have a B8 Avant Prestige with ADS, Sports Package (and some other toys) and reached out to Stasis repeatedly but have not gotten a response. Will it interfere with ADS? Would be neat to map it to the Individual setting only, leaving Comfort, Auto and Dynamic intact. Has anyone experience with ADS and chipping?
