Results 1 to 10 of 10
    Senior Member Two Rings mainer0311's Avatar
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    Blinking coolant light
    My coolant light has been blinking since I bought the car. The coolant gauge has intermittently worked, so I replaced the temp sensor but it didn't fix the problem. The light still blinks and the temp gauge still works when It wants to. The coolant bottle has enough coolant that it shouldn't be on. Could the sensor in the bottle be causing the light to blink? And if it is that how come my gauge doesn't work?
    Cooper
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Blinking coolant light
    whats the symbol look like? try topping off the coolant bottle and see if it goes away. wont hurt anything
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    The coolant bottle is topped off and the light still blinks.
    This is the light
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Might want to try pulling the plug off the bottom of the tank and see if another warning light comes up, if not then one of the wires on that harness might be broken.
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    I tired that at one point and the light continued to blink with no additional lights coming on.
    So I must have a broken wire going to the sensor on the tank.
    Where do those wires end up? I'm thinking it would be easier to run a continuity test instead of having to physically trace the wires.
    Cooper
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    Thermostat dude, probably stuck, happens all the time. Get it checked out asap.
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    But would a stuck thermostat cause a blinking light?
    Oct 19 2008
    South Africa
    Mine was, the light was on all the time, temp gauge was also all over the place.
    My radiator was cold to the touch, after the new thermostat(the first time, and second, and 4th and 5th....) it went back to normal. Might want to check that out first. I stopped putting water in mine and the problem went away.
    Jul 07 2004
    socal
    Quote Originally Posted by mainer0311 View Post
    Cooper
    Make sure to do a continuity test on the sensor on the bottom of the tank to see if the sensor is working correctly before you start doing tests on the wires.
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    I guess I'll toss a thermostat in it this weekend along with the other stuff I planed on working on. It sucks being at school away from being able to work on my car.
    Any tips on doing the thermostat? It doesn't look to be a simple job but we'll see.
    Cooper
