Results 1 to 36 of 36
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    KO4 or GT2X? $2k Budget
    Okay, I want my car to be faster, but I don't want to spend much more than 2k on a turbo upgrade. Any suggestions?
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: KO4 or GT2X? $2k Budget
    thats a really tight budget. just a k04 with a k04 flash is going to be close to your budget if not over. pc16 file would need an intercooler so +500, injectors +/- 120, flash +/- 500, k04 +750, then the exhaust, clutch, etc. maybe you should wait a bit longer and save up some more
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Sep 06 2007
    Bricktown, NJ
    why don't you just max out the k03 with full bolt ons for now, i hear you can get about 280lb/ft out of those little suckers, but only about 220 hp. either way, youll be looking at:
    -FMIC (500)
    -383cc injectors (200 used)
    -exhaust (750 for a good stainless steel borla one)
    -Tune (awe - $400)
    then when you get some more money you can just upgrade to a k04 and everything will still bolt right up. then you can get a pc-16 file from awe for 200 extra.
    May 04 2008
    Columbia, SC
    Okay... The clutch & exhaust is a separate budget.
    I was looking at:
    K04-015 + Gaskets/Bolts - $965 (Kinetic Motorsports)
    32lb Injectors - $150 (SprayIt!Racing)
    Adj FPR - $175 (ECSTuning.com)
    PC16 Tune - $300 (GIACUSA.com)
    eBay FMIC - $300 (ebay.com)
    Total $1890
    Like I said, the clutch and exhaust are a separate budget... I am going with the SouthBend Stg3 Clutch & AWE Flywheel, Exhaust will be a custom built Magnaflow setup.
    Veteran Member Three Rings leon's Avatar
    Nov 28 2004
    A4 1.8T Quattro/VW Polo 6N
    The Netherlands, Europe.
    If youre going Garret, skip the GT2X en take the GTRS, than you have a ball bearing turbo..
    I would save more money and go GTRS...
    A4 1.8T QUATTRO
    Garret GTRS turbo/Forge DV007/Bosch 440/Bosch 044 fuel pump/HT 3" SS TIP/HT 4" SS MAF/Autobahn FMIC/Carbonio CAI/Racekat/2.5" SS HT Exhaust/Eisenmann Muffler/034 High Flow manifold/Mocal plate,Setrab oilcooler/Porsche Brakes/Eibach Pro Street S/19"BBS Le Mans
    Senior Member Three Rings RudeBwoi's Avatar
    Jan 05 2005
    My 2000 1.8T, Quattro 5spd
    id skip the SMIC, you can prob piece together an fmic for $500 pretty quickly through ebay...
    GIAC Stage 1 ::: H&R S4 Coilovers ::: V&S Short Shifter ::: B5 Rs4 Reps ::: Intake ::: N75R ::: Tints ::: 12'' Kicker Square Sub
    Need to sell this A4 asap...SOLD
    May 04 2008
    Columbia, SC
    Will the SMIC not be sufficient for the K04? I do not plan on going any bigger with the turbo... I was actually happy with my chipped K03, but my turbo is dying and the wife approved my $2k K04 idea :D
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Quote Originally Posted by nrowensby View Post
    I know road course racing my SMIC will let the car heat soak after 2-3 laps on a 40 degree day with a POS stock turbo. For drag racing you might be able 2 get a few runs off it. All depends what you want to do. If your gonna do hard driving for more then 1320' at a time FMIC is a must, even for stock turbo chipped.
    May 04 2008
    Columbia, SC
    Quote Originally Posted by bob12312357 View Post
    Okay... is that an upgraded SMIC or the stock one? I guess I will plan for an eBay FMIC setup then :D
    Aug 16 2007
    Buffalo NY
    ebay fmic $300... you dont need a high end fmic for k03/k04
    http://cgi.ebay.com/ebaymotors/98-01...Q5fAccessories
    Aug 16 2007
    Buffalo NY
    if you were happy with the k03, im sure you will be very happy with the k04... Same spool and about another 50ft.lbs/tq
    May 04 2008
    Columbia, SC
    Quote Originally Posted by slopoke View Post
    That's what I wanted to hear... Now I can't wait to get it all together and get it on the car.
    Dec 05 2007
    There are a couple of quality FMIC kits being sold on classified sections on both here and fourtitude. And an ebay one should not cost you more than $350. As for the $2,000 budget, you may need to add maybe an extra $500 and you could have a set up.
    Link (tuning and injectors will cost ~$800, but can always be sought out for used/cone filter can be had for ~$30)
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    id say GT2x, waaay more top end than the k04 can provide
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Established Member Two Rings Kaytek's Avatar
    Nov 19 2005
    Ottawa, Canada
    What about the tuning for the GT2X? Unitronic? Tweaked K04 file?
    2001 1.8TQ Tip - GIAC X - Startup Racing Vogtland GTs
    May 04 2008
    Columbia, SC
    What do I need to add another $500 for? What's wrong with this?
    32lb Injectors - $150 (SprayIt Racing)
    Total $1890
    Oct 14 2008
    2003 A4 1.8TQ-M, 1990 300ZX TT
    Long Beach, CA
    Why don't you just go with the Revo K04 kit?
    http://www.ecodetuning.com/shop/cart...t_detail&p=256
    Edit: I thought I saw the price of this at $1500 a few days ago, not sure if they raised it or if I am dreaming things
    2003 Audi A4 1.8T Sport Quattro 5 Speed
    ~~VMR V710's 19x8.5 +35 * Sumitomo HTR-Z III 235/35/19 * Bilstein Struts * Neuspeed Springs * Boosted Technology CAI * GIAC Tuned * Audi TT Diverter Valve * AMS Short Shifter * 35% Tint * Clear Signals~~
    May 04 2008
    Columbia, SC
    Quote Originally Posted by KevinZtwin View Post
    EuroCode Tuning / Revo K04-15 Turbo upgrade
    (K04 Turbo Upgrade for the 2002-Up Audi A4 1.8T Models All)
    Dec 05 2007
    I was referring to if you wanted to go the Garret GT ball bearing route. I always thought the k04 to be rather pointless if you are looking for an upgrade (not pointless, but I have the k03s so it is pointless to me) . As maxspeed said, go with a GT2x if you want to upgrade. Or simply replace the stock turbo with a used one for $150 or so. That is what I would do anyways. That extra 50-75 hp is not worth the 2 grand in my opinion. But if it is 125+chp, then that is a different story. Just IMO.
    Oct 14 2008
    Long Beach, CA
    woops, duh..
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    I ran my GIAC Hammer file Ko4 with the stock side mount for almost a yr if i remember correctly... yeah it heat soaked like a bitch but it ran fine... Picked up a RaceTec fmic this past summer and made a huge differance! Pulls and pulls through the gears!
    But you dont NEED a fmic right off the bat if your going KO4, its just a good idea to get one soon so your not heat soaking like a bitch!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    If you dont mind getting used stuff, its not hard to build a budget BT setup for under $2500
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    May 04 2008
    Columbia, SC
    This is my daily driver and I really can't afford to have a lot of problems... I think I am just going to buy the K04 setup and be happy. As I said before, I was content with the chipped K03, I don't need a ton of HP to keep me happy.
    Veteran Member Three Rings Brooksthepro's Avatar
    Apr 29 2005
    2001 Audi a4, loud ass gocart!
    Santa Barbara, Ca
    I was looking at:
    Total $1890
    u dont need a clutch right away. been on my k04 for over a year and my stock clutch is fine. Just dont launch the shit out of it all the time.
    u dont need an exhaust right away either...i was on my stock for a while before i upgraded to the custom magnaflow.
    i needed an TT MAF for my hammer file. Not sure about yours though.
    u can pay $100 less for your FPR if u just get a 5bar fpr....i think thats all u need for the p-16 file....dont quote me though. do some searching but heres the link: http://www.supremepowerparts.com/2/1...ttro_1.8T.html
    also. if your upgrading because your k03 is pooped. prepair to pay for other repairs besides just the turbo. My k03 was broken when i upgraded and my exhaust manifold and cat were done for.
    good luck! i wish my hammer file cost $300!!??! jeez i payed like $800 for mine!
    edit: oh, and about the fmic. I got an ebay one for around 300. Been perfect ever since. no heat soak whatsoever. the ebay core will suffice for the k04 but any larger and u gotta get something a bit bigger/better quality.
    edit again: did some searching for u. i was wrong. no 5bar fpr, u need an adjustable. and u dont need another maf either..
    GIAC FXK04/Gen380cc/TTMAF/FMIC/custom magnaflow/710n/Labree HFC/034 Highflow Exhaust Mani/17"Team Dynamics ProRace1/CAI/race springs/Rs4 Grille/VDO vent boost gauge/SS brake lines/x-drilled rotors/12in Infinity /600w Infinity amp
    SANTA BARBARA LOCALS!! SBEUROCLUB
    May 04 2008
    Columbia, SC
    Quote Originally Posted by Brooksthepro View Post
    Yeah, I have done a good bit of research on the K04 and what I will need. The clutch will be in before the K04 gets here because my stock clutch would slip occasionally when driving the chipped K03 hard. My K03 isn't completely bad, the seals are going though and as far as my wife knows... it's gone
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Because Revo is garbage?
    Go with the GT2X kit before a KKK kit.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by biketsai View Post
    yes it is
    - Clint
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    you would have to be getting some killer deals and not a ball bearing turbo. Cheap manifolds aren't worth the wasted time, ask Bassed(Ian) about that
    Anyways. back to the OP. $2K won't get you real far, for starters you haven't figured shipping on all those items.
    I killed my clutch with a plain K03 on chipped power (one week after chipping). I spent almost $1K on my flywheel and clutch alone. +$500 tune, +$400 exhaust, +$25 spark plugs, MBC $40, and free mods like gutting the airbox and hand porting the throttle body/intake manifold. I also replaced my K03 when it died for a K03s(60K on a stock car) for $170 shipped.
    I went the cheap route with my exhaust and I have been given a lot of shit for it, I'd advise otherwise.
    NTM good luck finding a K04-15 right now, last I knew they were back ordered.
    GT2x can make some decent power, but I'd wait it out and spring for the GTRS. They make more power and there's more tuning backing.
    As far as the list you have comprised, check the classifieds. You can find a set of TT injectors for $125-200 and they'll have a spray pattern better suited for our cars.
    EDIT: FMIC is the way to go. I can't make it 2 laps around Grattan, or two trips down the 1/4mi before my intercooler is heatsoaked.
    Jun 04 2007
    Austin/DFW, TX
    yes it is
    Well I did mine (sans exhaust) for $2300.
    My 5-Speed Swap DIY
    - B6 USP
    Oct 22 2006
    Quote Originally Posted by djwimbo View Post
    last i checked Ecs and kinetic had k04-15's
    May 04 2008
    Columbia, SC
    FREE SHIPPING from Kinetic on the Turbo... I don't imagine any of the other parts are going to be too awfully expensive to ship. Shipping on the FMIC is $50, so I need to add about $100 more to my list to cover shipping... Still under budget... :D
    I killed my clutch with a plain K03 on chipped power (one week after chipping). I spent almost $1K on my flywheel and clutch alone. +$500 tune, +$400 exhaust, +$25 spark plugs, MBC $40, and free mods like gutting the airbox and hand porting the throttle body/intake manifold. I also replaced my K03 when it died for a K03s(60K on a stock car) for $170 shipped. I went the cheap route with my exhaust and I have been given a lot of shit for it, I'd advise otherwise.
    I have already said two or three times in this thread that I will have a Southbend Stg3 clutch and AWE LWFW before the K04 install... I also mentioned that the clutch and exhaust is a separate budget.
    KineticMotorsports has them in stock... and ready to ship.
    I will definately look around for better deals, this is just a list to start me off and prove to myself that I can do it for what I want to spend.
    Nov 28 2004
    I wish i could tune for $2K...
    Thats the price of a GTRS in Europe...
    And an Ebay FMIC is not bad, i have one on my GTRS..
    A4 1.8T QUATTRO
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    you deff need an adj. fpr for the PC-16 file since it tends to run on the rich side even at 3bar which the tune calls for, FWIW when i had mine i ran it at ~2.7bar
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    http://www.audizine.com/forum/showthread.php?t=246362
    K04-001 Turbo - 895USD shipped
    K04-001 Turbo and install kit - 950USD shipped
    K04-001 Turbo and install kit with manifold- 1225USD shipped
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    May 04 2008
    Columbia, SC
    Yeah... I've sent him PM's.... Just waiting on some pictures... :D
