I have a set of Kumho MX's that are completely bald on the outside in the rear. I only have around 6k to 7k miles on them. I recently lowered my car (H&R Springs) a little over a month ago and I only drove it a couple of times before I aligned it (less than 125 miles). We aligned with the specs I found on Audiworld, but now I am not sure if it was correct. But I have only driven less than 1k miles, so I don't know if that is enough time to f these tires up that bad (they are very soft tires though). Here are my alignment settings when I took it in and what we set them too (I don't have the settings when I was at stock height).
Before:
Front
Camber: -1.7 L -1.5 R
Toe: -1.12 L -0.33 R
Set Back: -0.06
Rear
Camber: -1.3 L -1.3 R
Toe: -0.61 L -0.45 R
Total Toe: -1.06
Thrust Angle: -0.08
After:
Front
Camber: -1.8 L -1.6 R
Toe: 0.04 L 0.02R
Set Back: 0.06
Rear
Camber: -1.3L -1.4R
Toe: 0.12 L 0.14 R
Total Toe: 0.25
Thrust Angle: -0.01
Here is a pic. Is it possible something was left loose to cause my alignment to get jacked up?
