2000 6sdp..my car shit the bed. I was vagging the car got some DTC codes so went ahead to clear them.. I took it for a spin but it felt very lame!!!! the car made a bogging sound in 2nd gear ,I then went right back home, and switched the car off.. I retryed starting but car will crank for 3 sec then click dead like if the timing had skip, or something... continued with a jump from another car but same thing happens.. there was a red circular flashing light on the center display before all this had happend.. earlier I was going to change my cluster code from 0 to 1025 to accomadate my new VAST RS4 Hitachi MAF. I had entered the CV pump WSC code when this started in the very first, I then re-entered the correct WSC code in place, the red flashing light on the center display went away but no start ever since I chkd all fuse non seems to be blown..plz help.. some DTC code after I re scanned it...
Software Coding: 06711 Work Shop Code: WSC 05052 10 Faults Found: 18057 - Powertrain Data Bus: Missing Message from ABS
P1649 - 35-10 - - - Intermittent 17861 - Exhaust Gas Temp Sensor 1 (G235): Open or
P1453 - 35-10 - - - Intermittent 17865 - Exhaust Gas Temp Sensor 2 (G236): Open or
P1457 - 35-10 - - - Intermittent 16486 - Mass Air Flow Sensor (G70): Signal too Low P0102 - 35-10 - - - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent 16687 - Cylinder 3 Misfire Detected P0303 - 35-10 - - - Intermittent 17965 - Charge Pressure Control: Positive Deviation P1557 - 35-10 - - - Intermittent 16520 - Oxygen (Lambda) Sensor B1 S2: Malfunction
P0136 - 35-10 - - - Intermittent 16540 - Oxygen (Lambda) Sensor B2 S2: Malfunction
P0156 - 35-10 - - - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent Readiness: 0110 0101
