Results 1 to 8 of 8
Thread: blinking hvac
    Mar 23 2008
    philippines
    blinking hvac
    hey guys, i have a 96 1.8t so it has the old hvac design. right now the right side display blinks for about 2 minutes upon start up. also noticed that the a/c is warmer than usual. i dont know if the blinking is related to the "warmness" of the a/c. if anyone has an idea on what's goin on kindly chime in. havent vag'ed it yet but when i did the last time i couldnt communicate with the hvac im assuming its coz its an older model so i didnt bother vagging it yet. thanks in advanced.
    Mar 23 2008
    philippines
    Re: blinking hvac
    anyone???
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Re: blinking hvac
    yeah, that means it has a fault in the system.
    there is a method to get it to display the fault if you don't have a VAG.
    Mar 23 2008
    philippines
    Re: blinking hvac
    oh okay! thanks a lot! any idea on what that method is? or at least what to search for?
    Mar 23 2008
    philippines
    Re: blinking hvac
    finally got my vagcom working again but when i tried connecting to the hvac it started to read for awhile then it gave an error saying excessive communication errors... anyone have an idea whats goin on or how i can fix this? thanks in advanced...
    Mar 23 2008
    philippines
    Re: blinking hvac
    when i have the a\c on, the air recirculation icon goes off without me pressing it. when i press it again it goes off again after awhile. dont really understand whats going on. i tried the method where i check for faults through the hvac but there seems to be a lot of errors that i dont understand. anything i could check physically?
    Registered Member Two Rings James-NZ's Avatar
    Dec 03 2008
    96 A4 & a few non Audi's....
    Hamilton, New Zealand
    Re: blinking hvac
    Sounds to me like you might have a dry joint on the circuit board inside the HVAC panel, the dry joints can sometimes be found where one (or more) of the 4 wiring plugs meet the circuit. If you are not familiar with soldering circuit boards then find some one who is. Should be a reasonably easy fix. :)
    Apr 26 2008
    White Plains, NY
    Re: blinking hvac
    Quote Originally Posted by pao312 View Post
    Yeah, the HVAC can display the fault code on its display, along with a whole bunch of working values it is receiving from various sensors...
    Unlocking the Secrets within the Climate Control Panel (2000)
    Though the article above states it is for model year 2000, the tables are old and probably good even for your 1996.
