Results 1 to 13 of 13
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    HELP Flashing CEL!
    Oh man my car has been giving me nothing but problems in the last month.
    Anyways for the past two weeks my car has had a very very bad stutter in a low RPM PEOPLE DID NOT LISTEN and told me because i was in too low of a RPM however no one understood that it never did it before. When my car is in any gear but first at 1500-2500 RPM there is a very very bad stutter, almost like its stalling, then today and yesterday i got a flashing CEL, the check engine light stayed today, unfortuantly i cannot find my OBDII to scan my ECU however does anyone have an idea what this is? Coil Packs, tune gone bad? plugs(were just changed about 5-10K ago)
    Thanks,
    Stefan
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Jan 31 2008
    Re: HELP Flashing CEL!
    P0303 Cylinder 3 misfire, Anybody know what to do about this situation? How do i correct it? Coil pack maybe something bigger? Any suggestions
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    Swap coil packs around and see if the misfire follows.
    Senior Member Two Rings mainer0311's Avatar
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    20 bucks says it is the ICM.
    Swap a different coil pack into cyl 3, vag it. If it says with cyl 3 than it wasn't the coil pack if it moves it was the coil pack.
    If it stays with cyl 3 swap the injector out to another cyl. If the miss fire follows the injector than you know it was the injector. But if it stays with cyl 3 next step is to replace the ICM.
    If replacing the ICM doesn't fix the miss fire you've got bigger problems.
    Good luck
    Registered Member Two Rings
    Aug 08 2008
    Spain/Dallas TX
    i had the same problem like a month ago my car started shaking and sounded like a modded Subaru wrx and had a flashing CEL got it scanned and had the same code so i changed the spark plugs and nothing i still had a misfire on #3 so i replaced the coil pack and it still kept acting up, last i ordered a new ICM and fixed the problem i bet u anything thats ur problem.
    Good luck man
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Could be something as simple as an intake gasket. Had the exact same problem about a month back and replaced the plugs, plug wires and coil ignition pack. Found out the problem was just a faulty intake mani gasket.
    Jan 31 2008
    Where can i get an ICM and how much is one?
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    You can ebay one for about 65 bucks, it probably wont be OEM for that price but I have 20k on an ebay one and it is still working.
    If you want OEM go to ecstuning, it will cost you more money but will be better a quality part.
    you could always find a friend with a 1.8t and swap ICM's with them to make sure it is that before you spend the $$.
    Cooper
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    20 bucks says its NOT the ICM. he has a 2001. No icm on facelift cars. i'd change the plugs first since thats the cheapest route, then check all the connections for the coil packs since they get loose or get wet from time to time. then if it still happens i would change the coil pack. switch the coil packs around and see if it follows it. then you would know for sure.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings SFexBOY's Avatar
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    i'll bet $50 its a coilpack.
    '90 BMW 325i...SOLD!
    '89 BMW 325ix...SOLD!
    '05 BMW M3
    01.5 A4 1.8TQ (175K, owner since 4K)
    My cars.
    Jan 31 2008
    I have a 2.8 how can I switch them around if they are connected?
    Nov 09 2006
    Bronx, NY
    they unclip, just unbolt them, take off the clip and switch it with another coilpack and see if the misfire folllows
    2000 A4 1.8tq
    Jan 31 2008
    Where do they unclip?
