Results 1 to 23 of 23
Thread: ESP Issue
    Veteran Member Three Rings cleveland222's Avatar
    Oct 13 2005
    87 mustang gt, 01.5 s4
    Cleveland, Ohio
    Question ESP Issue
    So my stability / traction control is kicking in, cutting throttle, when it shouldn't be. So far, I've only noticed it doing this in 2nd gear, and early in 3rd under 50% + throttle. This is taking place when there is no reason for it: dry road, no wheel spin, etc. When I turn it off via the button on the dash it behaves itself.
    Any help would greatly be appreciated!
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Re: ESC Issue
    Quote Originally Posted by cleveland222 View Post
    Wheel Speed sensor is possibly starting to go bad
    Oct 13 2005
    Cleveland, Ohio
    Re: ESC Issue
    Quote Originally Posted by Evilevo View Post
    Thank you. Have you had experience with the same issue?
    Aug 06 2008
    Canadia
    Re: ESP Issue
    theres also that exciter ring issue, could have cracked.
    is your speedo doing anything strange, or yor ABS when your coming to a stop?
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: ESP Issue
    Are you lowered with suspension? That could be your problem. Most b5s I've talked to that are lowered have their ESP go off on random with them. I pulled (iirc) fuse 42 to disable ESP, as I was having the same issues.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Oct 13 2005
    Cleveland, Ohio
    Re: ESP Issue
    The car is lowered, slammed actually. How would this cause my issue?
    I haven't noticed anything strange with the ABS or speedo.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: ESP Issue
    My car is pretty slammed as well (24" front fender) and it won't mess with your ABS or speedo, just throttle cut essentially with ESP. I don't know why exactly, I just know it affects it exactly as you stated.
    May 26 2008
    MD
    Re: ESP Issue
    Pulling the fuse will trigger the ESP light on the dash correct? Will it throw a code also?
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: ESP Issue
    Yeah, it looks the same if we were to push the ESP button (solid traction Light).
    No code.
    May 26 2008
    MD
    Re: ESP Issue
    Quote Originally Posted by Rated S View Post
    No code.
    Ok, im gonna try that also. I had my traction control kick on at 130 in 5th, i was like WTF? My car is slammed BTW.
    Oct 13 2005
    Cleveland, Ohio
    Re: ESP Issue
    My car has been as low as it sits for two years now, and this problem is just coming about now.
    Did this issue take awhile to surface in your car?
    May 26 2008
    MD
    Re: ESP Issue
    No, it only surfaced after switch from K04s to RS6s.
    Oct 13 2005
    Cleveland, Ohio
    Re: ESP Issue
    If it's caused by having your car lowered I'd imagine everyone who lowers there car would run into this, and that it would become an issue immediately, not years down the road.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: ESP Issue
    A LOT of b5 owners I've met, including Simpply from WMS said this is a common issue and happens. Why it didn't happen earlier for you, I don't know. Could it be something else? Perhaps, i'm just letting you know similar things have happened for me and others I have personally talked to.
    Oct 13 2005
    Cleveland, Ohio
    Re: ESP Issue
    So, it happened to you as soon as your car was lowered?
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: ESP Issue
    No, it took a little while, but not 'years'.
    Oct 13 2005
    Cleveland, Ohio
    Re: ESC Issue
    Can anyone else chime in on this theory?
    May 26 2008
    MD
    Re: ESC Issue
    I was told this is a possibility by my buddy who has had 4-5 S4. Whenever i have asked him about a problem he has always been right. It is just something to look into. If you have a Vagcom it might be possible to log the wheel speeds for each wheel. Check to make sure they are the same or close. Not sure if that is possible or not as i have not looked into it yet
    Senior Member Two Rings turboSquatt's Avatar
    Oct 12 2008
    Fort Collins
    Re: ESP Issue
    FWIW I am on stock suspension and I have the ESP issue also...
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    Re: ESP Issue
    i have my esp turn off and abs light come on, then when i turn off and start again(the car) it goes away. happens at the exact same time
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Re: ESP Issue
    ESP is gay, makes me want to only buy an 00 next
    Registered Member Two Rings
    Dec 02 2008
    canada
    Re: ESP Issue
    hey i went to the garage this morning to make my alignement and then couple minute after the traction control light open and the abs too
    what the hell everytime i bring it to a garage i have other problem
    i am gonna scan it tonight to see what's going on
    and yes i am lowered
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: ESP Issue
    Mine will do it when i give it gas starting out of a turn if i excelerate a lil hard for example a left into tyraffic, this started after i slammed the car 24F/24R Going to raise the car in April and have it alinement done after, my summer tires rub a littl eover hard bumps being that low,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
