    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    which 2.8v6 spark plugs
    tried searching=no dice, i need to know what plugs the 2.8's take, its a 99 a6 Avant 2.8QT it has 104K and i think then need to be replaced, also is there a way to check the level of the auto tranny fluid?
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: which 2.8v6 spark plugs
    the tranny fluid level can't be checked per se, but i think one of the plugs if you pull it and fluid start coming out then the level is fine.
    for plugs, the stock temp is BKR6 plug. I love my Iridium IX (BKR6-EIX)
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Established Member Two Rings 2000Pound Geico's Avatar
    Oct 31 2008
    beantown
    one word for you my friend!!
    NOLOGY, NOLOGY, NOLOGY
    Nology sparks plug and cables are the absulute best in the industry!!
    there are the only sparks plugs that use real silver!!
    do the resaerch..
    and then come back to us and tell us what you think!!
    Nov 20 2005
    I got magnecor competition wires... been running strong for 100k, they also have a lifetime guarantee.
    is it 4:20 yet?
    Established Member Two Rings Snowhere's Avatar
    Mar 20 2008
    2001 A6Q Avant, 90 G60 Corrado
    Buena Vista Colorado
    Thumbs up Re: which 2.8v6 spark plugs
    With 104K, you should just change the tranny fluid. Your tranny will thank you by living longer!
