Results 1 to 4 of 4
    Senior Member Three Rings TheWrightAudi.'s Avatar
    Aug 07 2008
    White Rock
    apexi turbo timer problem!
    k i installed my turbo timer last month and it worked perfectly, then one day i tried to shut it off and it never started counting down, never turned off!..
    the timer just read the usual reading of 0.30sec.
    - after playing with it for about half an hour. i just stalled it and disconnected the battery.
    i reconnected it and it worked fine again...
    this has happened a few times now..
    wtf
    please help?
    1999.5,1.8T,5speed,quattro.
    Understeer -is when you go off the road and see the tree that kills you
    Oversteer-is when you go off the road backwards and dont see the tree that kills you
    Dec 05 2007
    Re: apexi turbo timer problem!
    Anything electrical has an inevitable fate of having issues. I would check the warranty (if you bought it brand new) and see if you can have it replaced. I went with a Greddy TT because it seems to have a better reputation amongst Audi owners for thier electrical products.
    And on a side note, stalling your car out because of your tt will lead to other problems that can cost $300+ for repairs. Such as transmission, alternator, etc.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    check to see if the wiring has good connection. i had an issue once where the wire to the obd connector got loose and would turn the car off and then count down
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Aug 07 2008
    White Rock
    bump!
