I have STFA and have found no response other than "check the fuses/check the bulbs", well I have checked the fuses and they are good (for both Central Convenience fuses #38 & #24 I believe) and I have tested every bulb and they all work. I am out of ideas as to what or where to look to in resolving this issue:
No Interior Lights - that means no map lights, no dome lights for front Pass. Driver and rear pass. or trunk, this also includes the driver and front passenger puddle lights.
The weird part is that the Glove Box light works and the rear passengers (both sides) puddle lights work and all the lights on the doors themselves work. I have checked codes with a Vag-Com and have found none, the central convenience controller is responsive and therefore I assume it is not the culprit (I ran measuring blocks for the controller and according the the controller the lights are "ON" when I open a door, turn on the lights, etc).
Another interesting and perhaps related issue is that the Auto-Dimming function was not working for the rear view mirror, when I removed the power connection going to the dome lights (the entire switch assembly which also houses the sunroof dial) it started dimming again but as soon as I connected the power back to the dome lights it would not dim but it does show the compass and a green light indicating it has power.
I am at a loss....
