Results 1 to 4 of 4
Thread: Im at a loss...
    Registered Member Two Rings SilverStr33k's Avatar
    Sep 29 2008
    01 B5 S4/STG3+, 03 SVT Focus
    Gurnee, IL
    Im at a loss...
    ok, so i got my emmissions notice, however i have an issue, my stg3 has had a cel for random multiple cylinder misfire for 2.5 years now however the miss is only below 2.5k rpm, also now im gettin the flashing cel for misfire, and to top it off, i removed my hks evc and im back on the n75 valve, my boost guage in 3rd gear goes 26, 17, 22, 14, and creeps back to 20 by redline...im guessing the boost issue is from the n75, however this misfire is killing me, the car has all new coil packs and plugs multiple times....also i dont have a vagcom, only a code scanner...
    "One time I left my exhaust open and someone stole my valve springs and my piston rings..."
    Ace of Spades Time Attack club member#1
    I will swap your trim (all of it) for $100!! not a bad deal to save your frustration!
    Sep 29 2008
    Gurnee, IL
    Re: Im at a loss...
    i just scanned and im getting p0442-evap control leak, p0300-random multiple cylinder misfire, p1176-o2 correction behind catalyst, p1177-o2 correction behind catalyst
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Re: Im at a loss...
    Check your rear 02s and check for a boost leak
    Sep 29 2008
    Gurnee, IL
    Re: Im at a loss...
    will do, thanks, also is there a really common ignition problem with these cars or?
