Results 1 to 13 of 13
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    Question B8 A4 brakes different than B7 ?
    Just curious about this with respect to being able to use a 16" wheels for winters ...
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    Re: B8 A4 brakes different than B7 ?
    on a B8 A4? There's actually a 16" wheel available, so B8 A4 can definitely use 16" winters.
    Quote Originally Posted by Stevelev View Post
    Apr 27 2004
    thanks - where did you get this info ?
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    That's correct. On the new Audi A4 brochure it does indicates a 16" rim with 225/55/16 tires.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Veteran Member Four Rings afretes's Avatar
    Jun 23 2005
    '21 SQ5 - '20 Q3 - '06 BMW 325
    Caledon, Canada
    You won't be able to use the ones you had in a B7. The centre hub is a few mm bigger in diameter.
    Alex Fretes
    Fleet Manager - ABS
    E-mail: [email protected] - Tel: 647-984-2834
    Jun 02 2008
    I think he was referring to brake clearance, not hub?
    Quote Originally Posted by afretes View Post
    Oct 24 2008
    N/A
    I thought 16" are only available for fronttrak models?
    Not sure if there's any difference on the brakes between the fronttrak and quattro models
    Jun 23 2005
    Caledon, Canada
    Quote Originally Posted by sakimano View Post
    I thought he was asking if he could use B7 wheels on the new B8.
    Alex Fretes
    Fleet Manager - ABS
    Mar 19 2004
    Well, you still can use the B7/B6 wheels. All you have to do is machine the hub diameter a bit bigger.
    Apr 27 2004
    Thanks guys. Although the question was about the brakes (I assume they're the same), Alex gave the info required: A wheel that fits a B7 will not necessarily fit a B8 but this is due to the larger B8 hub size and NOT a brake clearance issue.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Jun 23 2005
    Caledon, Canada
    Are you going B8 Steve?
    Alex Fretes
    Fleet Manager - ABS
    Apr 27 2004
    Nope, not without speaking with you first ! I love my S4 ... especially these days with relatively cheap gas. I just wanted to know for interest sake ...
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Jun 23 2005
    Caledon, Canada
    I thought so. It'll take something very special to replace that S4 Avant : )
    Alex Fretes
    Fleet Manager - ABS
