Price is $625 SHIPPED
The first part of the upgrade is front and rear Rotora drilled/slotted rotors. The 1 piece rotors are much more durable then the stock units. Because of the drilled and slotted design, they dissipate heat much more under hard braking then the stock solid face. The rotors can be used with street pads or race pads as long as they are bed in properly. These rotors work with the stock calipers and will provide you with much improved braking.
Next we include steel braided brakelines. Agency Power has DOT approved steel braided brakelines for the front and rear of the Audi B7 A4. The lines feature CNC machined fittings and then a smoked gel coat over the the line for protection and longevity. The steel braided brakelines do not flex under brake pedal pressure like an OEM line does. This gives you a stiffer pedal feel that does not "MUSH" down as easy.
Lastly, the best way to prevent brake fade from constant hard braking on mountain roads or the race track is to get rid of the stock brake fluid and upgrade to a synthetic. We use the Motul RBF600 Dot 4 brake fluid in all our cars. This fluid has a much higher boiling point. To date, in all our street or track cars, we have NEVER boiled the fluid with Motul. The synthetic brake fluid inconjunction with the steel braided brake lines will provide you with a solid pedal feel and response.
For an additional cost we have several different types of brake pads from Hawk, Axxis, Mintex, and Pagid. Consult me about the type of driving you are doing so I can recommend a great replacement pad.
For those wanting to do a big brake upgrade, we carry Rotora, Brembo, and StaSIS at a GREAT PRICES.
B7 Performance Brake Upgrade Package Includes:
- Front and Rear Drilled/Slotted Rotora Rotors
- Front and Rear Agency Power Brake Lines
- 2 Bottles of Motul RBF600 DOT 4 Brake Fluid
- FREE SHIPPING
