Results 1 to 3 of 3
    Oct 20 2008
    Philly
    VAG COM Question
    I just did an HID conversion and have been having problems with my break, abs, and ESP lights coming on when i turn on the hid lamps. Also it will knock out my speedomitor. After i turn the electrical system off and on twice the codes clear out and everything goes to normal. I was reading that with the vagcom tool you can choose what type of light you have in the car. Do you guys think that this will solve the problem? Also does vagcom log the errors?
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    Re: VAG COM Question
    Quote Originally Posted by kev659 View Post
    i have that problem too if i turn on my lights before i turn on my car...
    if u let the car run for like 10 secods atleast then turn them on, it should be fine
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    this is known problem and you are not alone.
    It is the ballast at driver side is placed too near the ABS Module.
    The ABS module is very sensitive.
    Try to reallocate the ballast at driver's side as far away from ABS Module as possible and your problem will go away.
