Results 1 to 20 of 20
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Weird coilover problem
    I have a set of h&r ultralows. The passenger side sits lower than the drivers side. When I raise it up, it eventually settles to its original height. The perch, however, remains higher. No matter how high I go, it keeps sinking back down. The wheel on that side is also angled slightly outward in comparison to the drivers side. Control arms seem alright. The spring seems fine, so Idk what the issue is. Any help? Thanks in advance.
    the homebrew'd s4
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Re: Weird coilover problem
    Quote Originally Posted by Overboostin View Post
    I have the exactly same thing. My front right is a bit lower than the left.
    Swapted front coils and same.
    I was wondering if the previous owner had an accident with her before.
    Look's like a litle twist in the car but not sure.
    I don't know where to take mesurements for this or should i put it back to normal height.
    It was that way before i made the stage three swap also so i don't think it has to be something about subframe.
    Oct 14 2007
    Val-Belair
    I have a machine shop that will make me new spacers to raise front of about 9mm. I shall see. I almost forgot to say that i have all front control arms replaced last summer and changed nothing.
    Mar 15 2007
    New England
    I don't think my cars been in any accidents. Hopefully not at least. bump
    the homebrew'd s4
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Bent sway bar?
    "Obsessed" is a word that the lazy use to describe the committed.
    Registered Member Two Rings SilverStr33k's Avatar
    Sep 29 2008
    01 B5 S4/STG3+, 03 SVT Focus
    Gurnee, IL
    i also have this issue with my h&r sport ecs kit however i just found out i have a twisted subframe and need all new control arms all the war around they are bad........the disapointment continues
    "One time I left my exhaust open and someone stole my valve springs and my piston rings..."
    Ace of Spades Time Attack club member#1
    I will swap your trim (all of it) for $100!! not a bad deal to save your frustration!
    Mar 15 2007
    New England
    Quote Originally Posted by audimeister View Post
    Bent sway bar?
    Checked today. The sway bar seems fine. What happens is if I jack the car up and let it back down, it sits slightly higher, but then if I push it down, it goes down adn sits there. Bad spring maybe?
    the homebrew'd s4
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    when you jack a car up you take load off the suspension, when you set it back down it needs to settle in. and when you push down on it, you're basically making it settle in quicker, nothing wrong with that I believe.
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Dec 06 2006
    09 Subaru Outback XT, JD Tractor, EZ Go,
    Middletown, Ohio
    gain a little weight it will even out
    Mar 15 2007
    New England
    bump for ideas
    the homebrew'd s4
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    BUMP!
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    bump for ideas
    Is your strut Blown?
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Mar 15 2007
    New England
    Quote Originally Posted by s2the4 View Post
    No, but I don't think that would cause the problem. The shock controls the motion of the spring, compression and rebound, not the actual height.
    the homebrew'd s4
    Oct 14 2007
    Val-Belair
    Quote Originally Posted by SilverStr33k View Post
    How did you find that your subframe was twisted? I'm pretty sure the other owner had an accident with the car.
    You can use this as a bump overboosting
    Nov 02 2006
    Western Mass
    Have you taken the strut out and pushed it down to see if it does indeed rebound?
    ...For now
    clicky
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    +1 for that
    Sep 29 2008
    Gurnee, IL
    Quote Originally Posted by Reich View Post
    I went to my alignment shop, and they got the rear lined up and they went to do the front and apparently there is supposed to be some side to side adjustability in our front subframes to even out camber between side, long story short, mine wotn budge either way, we took measurements and front to back is off by almost a 1/2 inch and side to side the front is around 1/4 inch smaller, to make sure i wasnt crazy i compared to my buddies 30k mile weekend/summer driven no accident s4 and my measurements are the same amounts off from his...so thankfully jason from JHM gave me scrapyards to call to find a new one, i think the previous owner did crash this car and forgot to mention it, also my passenger side axle is rubbing my shock housing for some reason.....gotta measure the c/a's now to see whats wrong there. SORRY FOR THE HIJACK...
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    Check your bump stoppers...that's where my issue was.
    Mar 15 2007
    New England
    Quote Originally Posted by Allaidback View Post
    Can you explain what was wrong and how you solved it?
    the homebrew'd s4
    Oct 14 2007
    Val-Belair
    Thank's a lot that makes a lot of sense.
