Results 1 to 11 of 11
    Jul 08 2008
    04 A4 1.8T
    UK/HK
    S-line suspension bump stops vs non S.
    Hi
    Need some advice as I have the below S line suspension setup which I will install on my non S sline. However, I am missing the correct bump stops which I believe are shorter than the ones on my car. Question is should I buy new shorter bump stops or just cut the longer ones I have now to match? I think the S line bump stops are 1cm shorter at front and 2cm at back, is that correct?
    Front shock: 8E0 413 031 CL
    Front spring: 8E0 411 105 CH Markings blue/white/green
    Rear shock: 8E0 513 033H
    Rear spring: 8E0 51 115 DK Markings blue/pink
    Thanks
    J
    Aug 26 2005
    Re: S-line suspension bump stops vs non S.
    I cut ~2.5 cm from my non sport bump stops, front and rear, being the amount of drop with the new springs, cutting out a middle section and rejoined the two ends using polyurethane glue. the two cuts where made so that the glued joint was the same diameter on both sides.
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    i bought new sport bumps when i instaled my neuspeed/koni setup.
    Jul 08 2008
    04 A4 1.8T
    UK/HK
    Hi
    Is it not possible to just cut from the bottom or top?
    Heateris
    How much were the new bump stops and shorter by non S by?
    Thanks a lot
    J
    Aug 26 2005
    Quote Originally Posted by jc_333 View Post
    Hi
    Heateris
    Thanks a lot
    J
    Sure, that is possible, but Audi designed the ends to be shaped the way they are for good reason, and I wanted to retain the ends on the bump stops as designed.
    Aug 16 2004
    SE PA
    i kind of forget because i installed my suspension about 3 years ago. but IIRC the bumps are about 30$ each and about a inch shorter. search around the fourms, their was a good side by side photo of the non-sport vs sport floating around.
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    i didnt do it at all and i think thats why theres a clunking sound lol.
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Sep 21 2008
    05 B6 Sedan; 04 B6 Avant
    Derry, NH
    Pics comparing non-sport vs sport bumpstops can be seen here -> AudiWorld Forums: Did your mechanic re-use your non-sport bumpstops? that can make a difference
    2oo5 B6 Sedan Q | Dolphin Gray | SE | Platinum interior | 1.8T | Tiptronic
    2oo4 B6 Avant Q | Silver | Platinum interior | 1.8T | Tiptronic
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    I've got an extra set of sport bumpstops for sale. PM me if you're interested.
    Jul 08 2008
    04 A4 1.8T
    UK/HK
    Hi Guys!
    Thanks for the replies, looks like I better chop mine to the right size or buy new before I install the shocks.
    Thanks
    J
    Aug 16 2004
    SE PA
    Quote Originally Posted by francis_a View Post
    that's the photo i was talking about.
