Results 1 to 4 of 4
    Active Member One Ring Betzman's Avatar
    Jan 21 2007
    Kingsport Tn
    Pop noise when I hit the brakes
    Hey.. need some help with a issue I have with my Avant. 25 or 30% of the time when I hit my brakes I'll get a pop from the right wheel area. The left will do it 10% of the time. It does it forward or backwards also.
    I took it to a mechanic and he checked it out and said nothing was loose but he couldn't "hear" it when he drove it. seems to be getting worse as time goes by. Could it be brake pads moving around? Need to get this solved. Thanks
    2001 A4 Avant 1.8TQ
    Veteran Member Four Rings SFexBOY's Avatar
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    Re: Pop noise when I hit the brakes
    pads separating from the backing plate. Replace the pads and you should be good.
    '90 BMW 325i...SOLD!
    '89 BMW 325ix...SOLD!
    '05 BMW M3
    01.5 A4 1.8TQ (175K, owner since 4K)
    My cars.
    Established Member Two Rings oneighty's Avatar
    Aug 30 2007
    what ended up being your problem, im getting a similar noise...
    -Jonathan
    '00 A4 1.8T K&N | InMotion Tuning | Forge004 | AutoMeter boost gauge | Eibach ProKit | ST sports | Avus S4 | 6000K HIDs
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Or Cv axles
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
