Results 1 to 12 of 12
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    99.5 aeb issues HELP
    OK so cel went on the other day but drove normal..I dont have a vag cable yet.. Well today it wouldnt start unless i gave it gas, it would just keep turning over.. Then once it did start it wouldnt rev down normal at red lights and hang around 2500-3500 and putter and sputter really hard like in and out of boost while driving..like in 5th it bucked really hard..wtf?
    I would think the rpm's would be a really bad boost leak but the sputtering? Oh and today was the first snow fall ugh! Dont think the cold has anything to do with it but i dont know...
    Feb 27 2005
    North Wales, PA
    Re: 99.5 aeb issues HELP
    maf
    Aug 16 2007
    Buffalo NY
    so why will it start if i floor it? This cant be because of the sea foam i did 2 days ago could it?
    Aug 16 2007
    Buffalo NY
    how much do used maf's go for? Can i upgrade it at all for the k03? I would rather go aftermarket if possible but i only see bt guys running vr6 mafs
    Aug 16 2007
    Buffalo NY
    Could my plugs be bad from the seafoam? Happened to this guy..(bottom post)
    http://www.audizine.com/forum/showth...&highlight=maf
    Feb 27 2005
    North Wales, PA
    who knows. we are all just guessing at this point until you get your car scanned.
    Aug 16 2007
    Buffalo NY
    should i of changed my plugs after the seafoam? i just put them in maybe 5k ago...
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    it sounds like your maf
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Holy F dude, relax, slow down a bit and things will become more clear.
    Unless you were dumping the SeaFoam in front of the MAF, I don't see any possible way that it would cause the MAF issue.
    However, it does sound like a MAF issue (not caused by seafoam). You will want to inspect you plugs, but replacing they probably isn't needed at this time.
    Another possibility is that you have a boost leak. I forgot to tighten down my boost pipe to my throttle body once and it did about what you say is going on. I didn't make it to 5th gear though, only 3rd.
    Pop the hood an have yourself a look around, double check anything you may have tampered with when you did the seafoam - vacuum lines, boost hoses, etc. You never know, it might just jump out at you.
    Aug 16 2007
    Buffalo NY
    well my boost gauge is saying everything is ok.. -24psi vacuum to 7psi wot
    Apr 14 2008
    a4 avant
    marlboro
    tim for a green top coolant sensor
    -vrt-
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by slopoke View Post
    well my boost gauge is saying everything is ok.. -24 InHg of vacuum to 7psi wot
    fixed.
