Results 1 to 22 of 22
    Oct 30 2006
    B8 A4 Avant 6spd
    1st Caps Run. *update* 6.68 caps
    So seeing that I finally have a laptop (Thanks to TommyGunn), I went logging tonight.
    I am running a custom tune written up by Greg@SSP, This is the first revision.
    Caps 6.92, this makes it the 6th fastest k03 Caps time on ModifiedA4.com
    All the car has is a 3" turboback with magnaflow resonator and magnaflow muffler. A forge 007 and a cheap pep boys cone that a just happened to be laying around in the trunk of the car when I purchased the car.
    Funny part is, car was a little heat soaked from previous run, because I ran out of room, coasted for a little bit and went at it again up a minor uphill.
    My trunk is full of tools and parts, I honestly didn't expect to remotely come close to any fastest times. I'm sure if I didn't have anything in the trunk and did this on a level road the car is faster than the 'record' 6.83
    The file still needs to go through a few revisions, but I'm sure there still some power to be found in my setup. Think of it as a last wave off to a k03 before I go 2.0.
    -18 718 GTS
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: 1st Caps Run.
    Good pull.
    Now, I must challenge your time. I really need to steal the VAG-Com from work during lunch to do it though.
    ... wonder what a 2.0L on a K03 would do?
    EDIT: just double checked, might be a mis-print, but maxspeed holds the "record" @ 6.28S on a K03. Like I said though, that might not be right, seems too fast for the turbo.
    Feb 27 2005
    North Wales, PA
    Re: 1st Caps Run.
    he was lemmi tweaked with meth
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: 1st Caps Run.
    Quote Originally Posted by djwimbo View Post
    Good pull.
    I might just find out, there might be a little time before I put the turbo on after the build. =D.
    -18 718 GTS
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: 1st Caps Run.
    Quote Originally Posted by Poopie View Post
    Is that cheating?
    Feb 27 2005
    North Wales, PA
    Re: 1st Caps Run.
    nope
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: 1st Caps Run.
    Is that cheating?
    Nope, meaning he can run much lower intake air temperatures. That and the car runs more like on race gas.
    I'll pour some 100 octane in there, see how my caps are then.
    -18 718 GTS
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    Re: 1st Caps Run.
    ok wtf are caps?
    Aug 16 2007
    Buffalo NY
    Re: 1st Caps Run.
    Jan 25 2006
    A4 2.0T
    MD
    Re: 1st Caps Run.
    I ran a 3.82 caps last night... not bad considering my car is going no where fast @ 3800 RPM.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: 1st Caps Run.
    Quote Originally Posted by Don Supreme View Post
    I could do that in 1st gear ... dammit I need a BAT.
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: 1st Caps Run. *update* 6.68 caps
    I just came from a run home, got a much cleaner run that last night, got two runs in first was 6.68 seconds, then second 2 minutes later was 6.88 (guessing heatsoak).
    Mind you, I still didn't remove shit from the trunk!!
    Though I am getting odd throttle angle... Refer to screenshot.
    This makes me second fastest then =P Maxspeed you're going down.
    -18 718 GTS
    Oct 30 2006
    B8 A4 Avant 6spd
    -18 718 GTS
    Saint Cloud, Fl
    what is caps ?
    instagram ------------> low_enforcement
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by Militant-Grunt View Post
    your throttle angle and maf readings are whacky. its just a chipped k03s right?
    Oct 30 2006
    B8 A4 Avant 6spd
    Yes, custom tune. 3" turboback and cheapo intake.
    -18 718 GTS
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    HEY, that cheapo intake cost me 20 bucks a year ago for the original owner!! Congrats on the Time, seems like were both breaking records lately.
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    6.28 isnt a typo, nor is it the fastest my car has run during caps trial, 6.28 is an average speed based on 4 back to back runs(in opposite directions on the same road to factor our possible road angle) that modifieda4 requested i run as he deemed my 6.15 caps run "too fast". oh well, ill settle for the 6.28
    setup for those runs:
    GIAC chip, lemmituned for hella timing and backing off fuel a tad
    mbc ~ 24psi
    aquamist stage one kit
    borla cat back exhaust (2.25") - w/ stock CAT
    evoms intake
    fastest time that day was 6.15
    this is the same setup i ran my 14.3 with, there were a few more things i could have done to egg some more power out of her, mainly a test pipe an a FMIC, but i got bored screwing around with the k03
    "follow your dreams, you can succeed, BEEEEFF CAAAAAKE!!!!"
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    My K03 setup was Pre-CAPS so it didn't even get tested to see what it could do, but sure it would have ran some K04 CAP times.
    I do find it funny that Modified has completely ignored my newest CAPS times that I submitted which would put me back on top of the list seeing that I ran quicker then Ian's best time.
    Feb 27 2005
    North Wales, PA
    It takes a while. It took a few weeks for my k04 time to be put up
    Dec 14 2005
    indeed, there is a lag period he puts them all by hand, and im sure he has other things to do
    1999 Subaru Outback
    Aug 16 2007
    Buffalo NY
    thats bullshit i want to adjust the timing on my 99.5 ugh
