Results 1 to 18 of 18
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    how do i DIY flush my heater core?
    So after reading various threads and researching the topic a little bit, and also seeing the recent success of bedult1, i've decided i need to try to flush my heater core. But learning from bedult1 i also don't want to go to a shop and get charged $200 for something i could probably learn to do on my own.
    Symptoms:
    1. My heat is very fussy, works sometimes, sometimes not. When it does work, it takes a very long time to get warm. But it never gets as hot as you think HI should be. And it usually has the most problems the colder the weather outside gets. When the weather is in the lower 40's or below there is absolutely no heat no matter how long i have it on, it just fills the cabin with cold air; when it is 50 and above it gets warm but not hot. And the warmer the weather the faster it gets warm. It took about 10 minutes when it was about 64 degrees the other day and about 20 or longer when it was in the low 50's. So very iffy heat.
    2. I have/had a coolant leak, up until yesterday which i tried to fix with a new hose clamp where i could see a leak. Still waiting to see the results from this so i know if i have a leak elsewhere.
    3. Every time i open my coolant reservoir there is tons of excess pressure that spits out of the bottom of the reservoir through the bleeder valve (regardless of whether it is hot, warm, or cold; i've tried all 3 various times and it's always the exact same, just far worse when it's hot).
    4. Of the tubes that go through the firewall, 1 gets hot while the other stays cold.
    And because of this coolant leak that caused me to have to refill my coolant every 3 days because i would get that annoying beeping from my information center saying my coolant was low, i've been using water (coolant is too damn expensive to refill that tank every 3 days with). So i need to do a coolant flush once i see the results of my new hose clamp.
    If anyone has any input or can tell me how to do the heater core flush i would really appreciate it. TIA for any help!
    Jul 04 2008
    Seattle, Washington
    Re: how do i DIY flush my heater core?
    Also in order to flush my heater core do i need to flush my coolant at the same time as well?
    Jul 04 2008
    Seattle, Washington
    No one??
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    just take the lines off that go to it and backflush it (put water in, where it normally comes out) with a hose... or low psi air
    Jul 04 2008
    Seattle, Washington
    ok cool thanks. Is there a certain way to do this? Like with the water do i just put a regular hose up to the opening?
    Aug 20 2007
    97 Jeep Wrangler
    you could make a nice little piece to hose clamp on both ends and then turn the hose on... I would start with a lower pressure then go from there.
    Jul 04 2008
    Seattle, Washington
    cool. I went to home depot and i got some extra hose and a female adapter so i'm gonna hook it up and try that out.
    Jul 04 2008
    Seattle, Washington
    ok so my idea worked! And OMG! My heater core was clogged up pretty good. There was a ton of black and brown gunk and what looked like little chips of orange stuff. It came out really pink at first with a bunch of crap in it and it slowly got clearer and had less traces of crap in it. I ended up having to turn the water pressure up a little though in order to actually clear it out all the way.
    Ok now on to coolant flush.... where is the radiator cap or whatever i need to open in order to flush my coolant?
    EDIT: Oh and if anyone wants to do this, it will only cost you like $2 instead of $200. I bought a female hose repair kit adapter for $1.99 at home depot, had an extra hose clamp laying around, and went to action auto parts where they just happened to have the perfect length of my size heater core hose sitting there in back so they gave it to me for free. If anyone who's interested wants pics or a brief explanation let me know.
    Dec 06 2008
    Chicago
    Okay, i have the exact same problem and i would like to flush my heater core also but i can't find a write-up of the procedure... Since you have done this, can you please put up a step by step tuturial on how to do it and where everything is located??? Would really appreciate it if you can...
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    if you lay under your car on the left side there is a lower rad hose that clips into the Rad. also where it connects there is a coolant temp sensor, if you take the clip out of that and pull the sensor down/out. then do your flush thru there.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Dec 06 2008
    Chicago
    The CTS is located at the top? Are you saying i disconnect from the top and the hose that goes into the radiator at the bottom and then pour water through there?
    Mar 18 2007
    Ottawa Ontario Canada
    I too would also like to know how to do this. Come on people!!!! Cut us a break here!!!!
    In the 1.8t you're saying we have to get underneath the car and then your talking about pulling the CTS from underneath the car. Well from what I know, the CTS is BEHIND the engine at the top of the firewall and very hard to remove. Why are you telling us to go under the car to remove it. Is there another CTS under the car????
    I know it's a lot to ask but a step by step guide and some pics would be GREATLY appreciated.
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    I've done this before. Just disconnect the 2 heater core hoses. Buy 2 lengths of hose. Hook one from the core to a bucket. Then 1 from the other heater bung to the garden hose. Worked like a charm. Lots of crap came out. Then you gotta burp the air out, which is a bitch.
    Sent from my HTC EVO 3D X515a using Tapatalk
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Dec 15 2011
    Edmonton Alberta
    -Richard-
    2009 Rabbit. 1961 VW Beetle Canadian Std. 2012 Ram 1500.
    Darsh Import/Dubsport Inc... My very own VW/Audi parts and service shop
    Certified VW/Audi Tech 20 years +
    Jul 03 2010
    MA
    Quote Originally Posted by pablo_ottawa View Post
    http://www.audizine.com/forum/showth...eater-Core-DIY
    http://www.audiworld.com/tech/eng115.shtml (B5)
    2002 A4 1.8T Quattro
    APR 1+ 93/100, TT injectors; 034: cat + various mounts; 2.5" DP/custom exhaust; RS4 rear sway, Vogtland Jr. kit; NE rust mod
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    [edit] Hahaha, defiantly didn't see the the thread start date on this one...
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Veteran Member Three Rings TwinTipSkier's Avatar
    Nov 18 2009
    2012 VW Sportwagen 2.5S
    Tampa, Fl / Boston, Ma
    NECRO bump! always wanted to say that...
    Just went through this after rear coolant flange, had finicky heat. You flow hose water back from both heater core hoses to the right of the battery. I shot some compressed air through too, but I doubt you have to. To bleed air: with engine at temp, have someone hold gas to 1500rpms and you pull upper hose back enough to bubble out of the side or out of the small hole proved on top/end of hose.
    Wet and cold afternoon fur shure. But drive to work next day was nice and warm
    -John
    IG: johns550cc
    | '12 A4 Avant Brilliant Red | Thread |
    | '02 A4 1.8TQMS -gone |
    Senior Member Three Rings ggcrash's Avatar
    Nov 25 2008
    Orlando, Fl.
    Yes there are 2 coolant temp. sensors...#1 is behind the engine, and it helps if your hand size is small, that one is green, #2 can be accessed from under the car, on the drivers side close to the radiator, that one is black, If I remember correct. Also, when you change your thermostat, change the "J" plug too...the little black particles were most likely bits of your "J" plug O-ring being chewed up by the water pump and flowing through your entire cooling system...
