So I was installing a testpipe on a buds B5 a4.
All was going good till I bent the bottom turbo bolt that is screwed into the exhaust housing of the turbo (holds the cat). I was able to bend it back, but the threads are a little messed up. Can I remove this stud? If so, do I just get 2 nuts, tighten them together and then unscrew in inside one?? Any other suggestions?
TIA
-Chris
