Results 1 to 2 of 2
    Registered User Three Rings novitech-tuning's Avatar
    Apr 23 2008
    06 A3, MK2 GTI, MK4 R32
    Miami, Fl.
    November SPECIALS @ Novitech-Tuning
    Sorry for the delay in posting these up but here you go!
    As usual if you have any questions do not hesitate to contact us.
    Thanks,
    Novitech-Tuning
    2.0T FSI Fuel pump upgrade, $419 installed
    After months of extensive research and design, Autotech is proud to announce the release of our 2.0T Hi-Volume Fuel Pump Upgrade Kit. If you have felt the dreaded fuel cut in your 2.0T powered vehicle, this kit is an absolute must. Through the use of state of the art materials, heat-treating, and aerospace machining we were able to come up with an affordable yet extremely accurate product.
    Originally designed as a component for our upcoming turbo upgrade kit, this pump was designed to capacitate 300+ horsepower. Also, gains of 30+ft.lbs. beyond standard stage 2 programming can be obtained with fuel pump specific ECU tuning.
    2.0T FSI (A3, GTI, GLI and Passat) Fujita Cold Air Intake, $265 installed
    Full synthetic oil change service (includes complete vehicle inspection, service indicator light reset, top off all fluids and set tire pressures.
    4 cyl. $49.95
    6 cyl. $64.95
    8 cyl. $79.95
    Add $20 for rotate and balance if desired when doing oil change service.
    Apr 23 2008
    Miami, Fl.
    Re: November SPECIALS @ Novitech-Tuning
    All PM's have been replied, still a few days left for this offers guys !
