Results 1 to 12 of 12
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Paddles shifters not working from factory?
    '08 A4 2.0T non-sline Frontrack CVT here. I have the 4 spoke steering wheel with the paddle shifters. They can be clicked and the "+" and "-" buttons light up but they don't do anything!
    I had an '08 loaner base model but Quattro and the paddles work. Are my paddles supposed to be working? If so, can a vag-com fix this or should I take it to the dealer?
    Any help is greatly appreciated.
    Jan 01 2008
    Long Island NY
    Re: Paddles shifters not working from factory?
    take it to the dealer they should be working
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    do you have it in the mode where you can shift it?
    The usual things!!
    Resistor Install
    Apr 18 2008
    Jacksonville, FL
    shouldn't matter where the shifter is. if he hits the paddles, the tranny should switch into discrete-shifting-mode automatically and the display will change too. after about 10 seconds of not hitting either of the paddles (or sliding the shifter right then left) the tranny will go back to normal D.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Quote Originally Posted by cstarky15 View Post
    Yes I put it in manual mode and get the 1-7 numbers in the DIS. In that mode I can only shift with the "+" and "-" in the gearbox but not with the paddles.
    When you get it fixed, run a set of these!
    http://www.vividracing.com/catalog/a...8-p-55950.html
    Dan
    4809663040 x222
    Keep us posted on the progress.
    Veteran Member Three Rings S4King's Avatar
    Aug 01 2009
    Houston, TX
    Any updates on this?
    Veteran Member Three Rings cheemn's Avatar
    Jan 21 2010
    bunch of parts
    New Fairfield, CT
    You have the same problem of paddles not working on a factory fitted steering wheel with paddles? If they light up just make sure ya didnt by accident change the vag com settings. I forgot what they are exactly. They were either on here or on audiforums.
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Quote Originally Posted by S4King View Post
    Any update on an issue from 2008?!?
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Feb 06 2009
    328d, Tacoma
    Either way, read this thread: http://www.audizine.com/forum/showth...addle-Shifters it should lead you to a fix if you are "also" having an issue.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Quote Originally Posted by minameismud View Post
    This is exactly how my 2006 used to work, but in the last year or so, I can only use the paddle shifters in tip or S mode not D. Nothing happens when I press the paddles in D mode.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
