Results 1 to 16 of 16
    Established Member Two Rings DuviVr6's Avatar
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    Few swaybar questions
    well i've been having some trouble trying to find information for the audi!
    So i bought some S4 swaybars that supposedly are 29mm up front and 15mm out back!
    did the back end and indeed was better than my non-sport A4 one!
    but then I was about to swap the front one and it looks the same?
    my car is a 99.5 Avant 1.8t - I thought i would have been a 27mm bar not the 29mm
    both bars have different numbers on them
    the one on my car says: 8D04M HFHH9DE
    the "S4" one says: 8D04M HFHD8DE
    can anyone enlighten me? i didn't swap the fronts out cause they look the same!
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Few swaybar questions
    appearing the same and being the same are two different things.
    The S4 one should be a tiny bit stiffer. ... I said should, no promises.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    2mm is small and hard to notice. The s4 will be stiffer.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    Ive been having trouble finding sway bars as well for my FWD TIP, I know Neuspeed makes one for the rear, but what about for the front? Can I use the same one that the quattro uses?
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by 20A4Audi1.8t01 View Post
    Ive been having trouble finding sway bars as well for my FWD TIP, ...
    The front's should be the same. Obviously if you upgrade the size of the bar you will need the correct bushings, sometimes they'll squeeze in if it's not a huge upgrade.
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    so you guys say I should install the S4 bar i bought?
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    well drove a little bit today and the rear feels a lot better with the S4 sway! so i'm happy !
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    A4 non sport front bar is hollow.
    S4 front bar is solid.
    A4 sport front bar = S4 front bar.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Mike, any chance of a h-sport group buy or h-sport sale anytime soon?
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Kyle H View Post
    ... avalon motorsports $445, cheapest place I have found them. That's why I bought through them.
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    Quote Originally Posted by Mike@PureMS View Post
    hmm cool i guess i'll switch it out then
    so is the S4 bar 27mm or 29mm??
    Jul 19 2007
    San Diego, CA
    All B5 front bars should be 29mm. There are only 2. Nonsport (hollow) and Sport/S4 (solid)
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    cool thanks Mike Ur the shiet!
    Oct 08 2005
    Orlando, FL
    so in my case being FWD the s4 front sway will work?
    Jul 19 2007
    San Diego, CA
    On NOW. Check the GB forum.
    Yes.
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    HSPORTS ROCK!!!
    Eliminates body roll it's more drastic of a difference than night and day...
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
