Results 1 to 16 of 16
    Senior Member Two Rings fahrenheit955's Avatar
    Sep 30 2007
    Pittsburgh, PA
    High Idle in Neutral, Please HELP!!!!
    I'm really confused right now, My car was perfectly normal until today when I was driving to get some food at school today. I noticed when I put the car in neutral, the idle would go up to 2000rpm. Then when it would go back to normal when put into gear. I ignored it, then the idle started going up to 4000!! I turned around and immediately parked the car. I tried searching but no luck. Im sorry if this has been brought up before. If someone can point me in the right direction, that would be great, Thanks.
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    Re: High Idle in Neutral, Please HELP!!!!
    gas pedal getting stuck down?
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Sep 30 2007
    Pittsburgh, PA
    Well if that was the case then why wouldn't it rev up when its in gear? When the car is in gear, it seems to run fine.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    TB alignment? I would vag the car.
    Sep 30 2007
    Pittsburgh, PA
    Where can I do that? I don't have a Vag com, and Im stuck at school right now. Does autozone or advance auto parts have one? I'm sorry, my n00bness is showing right now.
    Feb 20 2007
    ct
    The Generic OBD2 scanners I am pretty sure can not do throttle body adaption, I would go to the regionals see if anyone local has a VAG com that they can perform this. But for all i know its a simpler issue I'm just throwing out related ideas that could be simply/cheaply done.
    Sep 30 2007
    Pittsburgh, PA
    I should probably also mention that the check engine light did not come on. I don't know if that has anything to do with this.
    Dec 06 2007
    so here's what u do push ur foot down while the car is off on the gas, hold it turn the ignition on don't start it, count to 8, turn the key off count to 5 remove foot, leave key in car wait 2 mins and throttle is aligned
    -Kirk
    BetaAlphaTau Member #58
    Sep 30 2007
    Pittsburgh, PA
    Are you serious? or are you being sarcastic? I couldn't tell, not to be rude. Im a lil confused, i think what you said may have worked lol.
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Quote Originally Posted by fahrenheit955 View Post
    no that's the truth it no it is though ahha
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Sep 30 2007
    Pittsburgh, PA
    Quote Originally Posted by Charlescrs6 View Post
    haha thanks dude, I wasnt sure, i think it worked , we'll see tho.
    Sep 28 2008
    Boston, MA
    yeah but it will go back to ghey every other week or so, i realign just about every 2 weeks.
    Current: ISO RS4
    Sep 30 2007
    Pittsburgh, PA
    every 2 weeks??? there isnt a way to permanently fix this?!?!?
    Sep 28 2008
    Boston, MA
    well maybe your problem will go away but in our cars we have adaptive throttle or something similar that adapts to your driving style. The throttle alignment just resets it, which hopefully will solve your problem permanatly. It's fixed for now right?
    Current: ISO RS4
    Sep 30 2007
    Pittsburgh, PA
    Not really, I thought it was but I was wrong. I talked to a friend of mine who drives a gti and had a similar issue. He told me it could be the fuel sensor because when the idle is high, i press the gass and shift into gear and it temporarily goes away. He has a Vag Com and we're gonna see if that's actually the case.
    Sep 28 2008
    Boston, MA
    yeah good plan
    Current: ISO RS4
